Posted October 26, 201311 yr I'm putting together a budget system in a Ford F-150 I have a custom box with .69 cu feet sealed available for 2 10" subs. There is a lot of options I've been narrowing it down so far I'm leaning towards the Sundown Audio SD 10 Dual 4. I am going to be running a Class AB Mono channel amp rated at 1400 Watts RMS into 1 ohm load. There restrictions6 Inch mounting depth300 dollar budgetlooking for Dual 4 ohm subs or single 2 ohm subs(Want as much bass as possible from a 2 10" subwoofer sealed enclosure) Thanks for any help with picking the right pair of tens!
October 26, 201311 yr pretty sure the depth of the SA is more then 6 the sundown E is a great sub and works very well in a small sealed box, i recently did an install on a 13 f 250 super duty with 2 E 10s on a old memphis 1000 watt.. sounds bad ass.88
October 26, 201311 yr Obsidian Audio 10" V3 is spec'd out for super small enclosures. Port length is tricky in an enclosure that small though.
