I have 2 sa 12s in a ported box and I've been thinking of trying to build a 4th order or just buying some sa 15s and building a ported box for them. So my question is could the 12s be louder in a 4th order than the 15s in a ported box tuned to say 30hz? They would both be ran on a saz1500 and space isn't an issue for either and they would be ran in the same vehicle
12s in a bandpass wont gain output over a conventional ported box.
I thought 4th order were suppose to be louder or is it more about having a broader frequency range but equal output? Idk that's why I'm asking
nope just some bullshit that spread around the internet.
Your 12s are already in a 4th order enclosure.
Are you wanting to build a bandpass?  They are more complicated and only potential gains in output over a small range of frequencies.  If you aren't really good at designing and building enclosures now, I would suggest building your knowlege base or hiring out the work.
Yea I want to build a bandpass I'm just used to referring to them as 4th orders but I have a decent knowledge of box building. I've built multiple ported boxes but never a bandpass but I've been reading about designs and different ratios. I believe the hardest part is tuning. I've built my last couple boxes with interchangeable ports so I could do that to test out which frequency would work best for me.
the ratio business is also BS. what are you trying to achieve?
In this thread I was wanting to know if it's worth my time to try and build a bandpass for the 12s or just save up for 15s but overall just a loud daily setup
nope, either try a high tuning in the current box or save for 15s.
I already went from 30hz to 36hz and currently 45hz port... High tuned ports aren't really my thing I like my lows
SAs are very 4th order bandpass friendly. It can't hurt to try if you already have the subs - and if you don't like the output you can always go with the two 15s.
They do well with around 1 cube sealed and anywhere from 2-3 cubes ported each, and port area should be around half of your total cone area. This puts your sealed resonance around 45-47, and tuning the ported section to that number yields good results.
That's kinda what I was thinking I might as we'll try. So your saying for 2 12s 2 cubes sealed and between 4-6 cubes ported. What would be the benefit of going with 6 cubes I want to be able to play 25hz to atleast 40hz.
The ratio business is actually not BS. Changing the ported size affects the response greatly, with higher ratios generally having a more peaky output and lower ratios generally having a wider, flatter response.
If you're wanting to play that low, moving up to about 2.4 cubes sealed may benefit you. You would probably see more efficiency from 6 cubes ported, but you may start to lose some high and/or low end response.
For what it's worth, I know someone who did a forward firing 4th order with 2 SA-12s in a Tahoe. He used 2 cubes for the sealed chamber and had around a 4:1 ratio. It played flat within 2dB from 25-60Hz and was doing very respectable numbers when measured with a TermLab.
Edited by Tenacious
What are all the measurements of your current enclosure? How are you doing your changeable ports?
I'm at work so I can't get the dimensions but I remember it being around 3.8 cubes after displacement. I use a rubber weather stripping and just bolt it on. It seems to work I can't feel any leaks
I mean how are you changing the tuning? Like are you just putting different length ports in the enclosure?
Well that will be changing the internal volume also. . How did you figure out your gross and net volume?
I got the net from a kicker u app length x width x height and I kinda guessed on what the net is from the displacement of each sub and what I think is the displacement of the port but I made this box awhile back so I don't remember exact numbers plus I I'm not a math wiz so i don't know how to figure out the ports displacement anyways
So you don't know where the enclosure is tuned to. :P
If it were me I'd go with more cone area and ported box.
Your current enclosure mite not be what you think it is so I would probably figure all that out first. . Because who knows, it could be way off and you mite really be happy with a regular ported enclosure designed right. . . . .
When you get a chance post the dimensions of the enclosure and port area and length. .and Type/thickness of wood
I have a general idea. I just can't for sure say a exact number and I will measure it when I get home and post it
It's 3/4 in mdf
32 width
15 1/4 height
20 1/4 depth
Port size?
