Posted August 13, 201412 yr I was looking on the SSA store and was curious about the soundrive cables. They are on the pricey side, my question, are they worth it? Would the sound really improve as they lead you to believe? I've always run twisted pair, currently RF brand, never used coax before. From what I have read, if there isn't an existing noise issue, most any cable will do. Though, the only info I run across seems like it's all just speculation. I just moved my amps around and now my current rca cables are way too long.
August 13, 201412 yr Short answer is no. Rca's all do the same job. It's when you introduce noise is when some will do better than others with shielding. If you take care to run a 5 dollar pair it can do just as well as a 100 dollar pair.
August 13, 201412 yr http://www.amazon.com/65300-DIRECTED-AUDIO-QUALITY-CABLE/dp/B000ITZICS/ref=sr_1_3?ie=UTF8&qid=1407933427&sr=8-3&keywords=directed+audio+rca 65300 DIRECTED AUDIO 2 CH 1.5 FOOT HI QUALITY RCA JACK CABLE DEI PPI ORION A/D/S choice i use.
August 13, 201412 yr You might need something a bit longer than 1.5ft. Some people complain of them being stiff, but they do just fine for rca's http://www.monoprice.com/Search/Index?keyword=rca+premium
August 13, 201412 yr Author I had thought about monoprice, but since it will be a little tight under my center console I am looking for good flexibility.
August 13, 201412 yr I use all Rockford RCA's as well. They look nice, Grip well, but not to much. And look good.
August 13, 201412 yr Depending on your application and budget, they may or may not be "worth it" for you. All of our cables are shielded, constructed with very nice cable and connectors that tightly grip RCA jacks, and come with a lifetime warranty. Personally, I would prefer buying one nice set of RCA cables I could use throughout multiple installs rather than buy multiple cheap sets of RCAs. As far as twisted pair goes - unless you have balanced differential outputs/inputs then they're borderline useless. In car audio, differential is very rarely used (symbilink uses it) and when differential isn't used, shielding is the #1 form of noise rejection. Cable routing is still important as always, but even passing over stock wiring can introduce noise, which can be unavoidable in many cars.One last thing - all of our cables are assembled in the USA and tested before we ship them out. Edited August 13, 201412 yr by Tenacious
August 13, 201412 yr I have used NVX cables and have had no problems with them.Cable routing is the important part.
August 14, 201412 yr Popular Post To answer the original question; No, they are not worth it.Depending on your application and budget, they may or may not be "worth it" for you. All of our cables are shielded, constructed with very nice cable and connectors that tightly grip RCA jacks, and come with a lifetime warranty. Personally, I would prefer buying one nice set of RCA cables I could use throughout multiple installs rather than buy multiple cheap sets of RCAs.Not sure why you can't use less expensive RCA's throughout multiple installs as well. Or hell, if they were cheap enough don't waste your time pulling them from the car. Send them with the car, buy another affordable pair and still be ahead money, and time.Very few people need to use a warranty on cables. Of the few that do, it is still cheaper to buy multiples of a more affordable cable than to buy one expensive cable (and then potentially have to deal with trying to get it warrantied). Plus a warranty is only good if the company is still in business and, no offense, statistically you have a very low probability of being around mid to long term.As far as twisted pair goes - unless you have balanced differential outputs/inputs then they're borderline useless. In car audio, differential is very rarely used (symbilink uses it) and when differential isn't used, shielding is the #1 form of noise rejection. Cable routing is still important as always, but even passing over stock wiring can introduce noise, which can be unavoidable in many cars.Likewise if he is using a UTP cable and doesn't experience noise, then the shielding isn't going to matter
August 14, 201412 yr Or hell, there is nothing proprietary about your cables. He could probably buy the materials and build an equally good cable for less than yours are selling for unless you are getting really, really good discounts on materials.
August 14, 201412 yr I run skyhigh RCA's if you want I will send you a 3ft one that I have laying around so you can try it
August 14, 201412 yr Author I run skyhigh RCA's if you want I will send you a 3ft one that I have laying around so you can try itI appreciate the offer, but that wouldn't quite be long enough for my setup.Thanks for all the input everyone, pretty much confirmed what I had already come up with on my own. Time to shop around.
August 14, 201412 yr I get mine from sonicelectronix, either the Kicker or Rockford Fosgate. I been wanting to try monoprice for awhile.
August 15, 201412 yr Cables are rather simple. If you can't measure a difference electrically then there isn't. There is a reason manufacturers do not post electrical measurements as well. You can probably guess why.
August 15, 201412 yr Cables are rather simple. If you can't measure a difference electrically then there isn't. There is a reason manufacturers do not post electrical measurements as well. You can probably guess why.http://www.kimber.com/products/loudspeakercables/trifocal/xl/
August 15, 201412 yr Author I wondered who was going to be the wise guy and link to kimber. Lol As I was reading on other sites, kimber always seemed to come up there as well.
August 15, 201412 yr Cables are rather simple. If you can't measure a difference electrically then there isn't. There is a reason manufacturers do not post electrical measurements as well. You can probably guess why.http://www.kimber.com/products/loudspeakercables/trifocal/xl/I've done a bunch of measurements for Ray.
August 15, 201412 yr Cables are rather simple. If you can't measure a difference electrically then there isn't. There is a reason manufacturers do not post electrical measurements as well. You can probably guess why.http://www.kimber.com/products/loudspeakercables/trifocal/xl/I've done a bunch of measurements for Ray. Those cables are refucktard expensive
August 15, 201412 yr Author Going to give the monoprice cables a try. Just ordered two of these: http://www.monoprice.com/Product?c_id=102&cp_id=10218&cs_id=1021814&p_id=2864&seq=1&format=2
August 16, 201412 yr I have cheap ass 2.50$ raptor cables in vehicles for over 12 years with no problems
August 16, 201412 yr Author I purchased an optical cable for my home audio from monoprice a while back with good results. Hopefully this turns out the same. I almost got their RG6 cables for the double copper shielding, but I was worried about flexibility.
