September 19, 201412 yr Author What numbers has this truck seen in its history?[/quoteI believe sean said 162.xxThen mid 50's bosted by a few other owners...]
September 20, 201412 yr Author typically I would lean towards calling these next few pics....progress pics. ....however, that seems a bit too forward ...unlike my momentum on this project lately .lol
September 20, 201412 yr Author hard to see some of the obstacles in the pics....but there is alot of work to be done to get the inside of this enclosure smooth.
September 20, 201412 yr Author My video link did not work...let me try to find a different way.* wanted you to see the screw protruding into the enclosure. ...we had to cut them off and grind them slightly deeper than flush. I plan on skimming body filler throughout the enclosure.
September 20, 201412 yr Author way too much purple.....I look like a oompa-loompa after a session of sanding.
September 20, 201412 yr Author That is about where I left off at on the inside. ..and here is a few of the outside
September 20, 201412 yr Author URL=http://s151.photobucket.com/user/porkchop22_2007/media/Mobile%20Uploads/2014-08/20140821_100223_zpsbpilyag2.jpg.html]
September 20, 201412 yr Author Great progress so far brotherThe outside looks 1,000,000 times better too!Thanks brother
September 20, 201412 yr Good to see your recycling Chop. Most would of hauled that bitch to the crusher. Keep the pics coming brother.
September 20, 201412 yr Author My goals seem to keep changing each time I work on the truck. ...wonder what u guys would say if I told ya that I haven't started it yet.....nope....in fact...it most likely has 2012/2013 gas in it still. I have been hesitant to make a solid desicion on the alternator set up...which was disassembled when I picked up the truck.
September 20, 201412 yr This build would be insane by my standards, but for you? Just another walk in the park, right?
October 29, 201411 yr Author URL=http://s151.photobucket.com/user/porkchop22_2007/media/Mobile%20Uploads/2014-10/20141026_160638_zpsscidbktl.jpg.html]URL=http://s151.photobucket.com/user/porkchop22_2007/media/Mobile%20Uploads/2014-10/20141026_160609_zps10gxr3h4.jpg.html]Small update.....it is running! !!!!!!!!!
