What numbers has this truck seen in its history?[/quote
I believe sean said 162.xx
Then mid 50's bosted by a few other owners...
  • Replies 82
  • Views 16.8k
  • Yes this is correct genius...And quit neggin all my post your just making yourself look like a little bitch!!
  • jcarter1885
    jcarter1885
    Yes you usually change the thickness of the loading wall, height of the port or width of port just like any other enclosure to adjust the tuning.
  • Uhh yea..Every time he logs on i get but rapped..lol..Guess you must be hitting him from the behind
About the last of the before pics that I have I believe.
20140813_175036_zpshwjtmvsy.jpgtypically I would lean towards calling these next few pics....progress pics. ....however, that seems a bit too forward ...unlike my momentum on this project lately .lol
20140813_173349_zps3dxrkfie.jpg20140809_144230_zpstkcdnpgk.jpghard to see some of the obstacles in the pics....but there is alot of work to be done to get the inside of this enclosure smooth.
My video link did not work...let me try to find a different way.
* wanted you to see the screw protruding into the enclosure. ...we had to cut them off and grind them slightly deeper than flush.
I plan on skimming body filler throughout the enclosure.
20140809_144056_zpsvfmagqou.jpgway too much purple.....I look like a oompa-loompa after a session of sanding.
That is about where I left off at on the inside. ..and here is a few of the outside
Great progress so far brother
The outside looks 1,000,000 times better too!
Thanks brother
Great progress and new paint job is badass, love the work so far Chop.
Good to see your recycling Chop. Most would of hauled that bitch to the crusher. :D
My goals seem to keep changing each time I work on the truck. ...wonder what u guys would say if I told ya that I haven't started it yet.....nope....in fact...it most likely has 2012/2013 gas in it still. I have been hesitant to make a solid desicion on the alternator set up...which was disassembled when I picked up the truck.
This build would be insane by my standards, but for you? Just another walk in the park, right?
wow !! Great updates !!
  • 1 month later...
Awesome!!  Replacing that OLD gas too!  lol
Awesome to see it alive brother.
