Posted March 15, 20179 yr What would be the best box for a Nissan 350Z, I can't decide whether to go with 2 SA8's or a single X8, I will be powering it with an Arc Audio 2500CXL which puts out a little over 1000 watts.
March 15, 20179 yr Author If I want to keep the box in front of the brace firing towards the back only about 1.25 CF. Edited March 15, 20179 yr by JasonATI
March 15, 20179 yr That screams for a sealed 12. Most 10's won't fit in it ported and 8's don't really take up less space than a 10 once you add the extra port length required for the smaller box volume.
March 15, 20179 yr Ya i would say run a sealed 12 or 10 depending on your clearance. Throw that whole amp at a nice sub sealed and youll be all set.
March 17, 20179 yr Author So then either a SA10 or 12, or is there another series recommended for that air space and power? Thank You
