Eric Steven Horns new DSP settings
Edited by jcarter1885
  • Replies 401
  • Views 43.3k
  • jcarter1885
    jcarter1885
    Some of the equipment from the previous build and wires since I always buy extra to have. Enclosure should be done either this week or next week and Im still waiting on the sub but no biggie until I g
  • jcarter1885
    jcarter1885
    Sound deadening has began
  • jcarter1885
    jcarter1885
    I'm 80% done with the sound deadner, the trunk deck is next. I didn't do the under side yet because I don't feel like uninstalling the factory subwoofer till it blows or until my new Fi sub gets here.
Faital Pro PR160 new DSP settings
Fi Neo 4.7 15” new DSP settings
Daytime shots after wiping the enclosure down
Light show at night time
On 4/2/2022 at 1:25 PM, jcarter1885 said:
Thank you very much I appreciate it, stick around as there are more things to come and I'll be addressing some things I should of executed better.
I’ve recently picked up a 2021 VW Arteon SEL-P RLine with the Harmon Kardon in it. Low end lacks a lot, so I’m looking for a way to integrate a better sub setup.
Again, great work!
Again, great work!
I loved that thing man when I was car shopping, but for what I got the Passat at that time brand new it was a no brainer. But everyday when I drive by one of those I drool. Dope ride for sure and thanks man.
So far it seems that I have eliminated the basic rattles inside the car. The rear over head light console should be quiet now. I added one layer of Soundskins speaker foam ring dampening. If you look closely between the black squashed dampening, you will see a black plastic trim piece that is attached the top side of the headliner. That was smacking against the roof of the car. This deadener is about 1 inch thick give or take and thickness is perfect, I had to jam it in there but it works great.
What do we have here?
Got tired of the box sliding around and decided to go this route.
5 hours ago, Tirefryr said:
Man, that monochrome white with the black sub is sweet!
Thanks man and I absolutely think it looks killer as well. But as much as I love it especially with my trunk light. My next enclosure will be black with white aero port and white inside.
This white just isn't as durable as the black bedliner and it gets dirty just by touching it. Even when you wash your hands, that oil from the skin shows.
I really appreciate it, I think you gave me some of the idea before about either a white box or a white port. If it wasn't in this build log, it might of been in my Sonata build log.
Quick install in a 2017 Mercedes Benz C Class with the SSA Amp, sub is bridged on two channels. Other two channels will be used for interior speakers in the future.
I decided to not do the SMD fuse blocks and stayed with Jims Machine Works, they got here in two days after ordering which I was surprised.
The top covers are clear, I just haven't removed the protective covering yet. Don't want to sratch them so I'll wait till it's time to isntall until I do that.
  • 2 weeks later...
Getting the voltage controller knob and relay wiring done so the installer will have less work to do when the H/O Alternator gets installed at the shop. Excuse the dirty mats, going out of town soon and didn't have time to clean out the car. Still waiting on relays to be delivered.
  • 2 weeks later...
On 5/10/2022 at 7:15 PM, Tirefryr said:
Damn, you just keep on with the upgrade!
Haha yes sir, even on vacation I was putting in some wiring work while at the cabins.
Relays are here and I also bought new 20amp Bussmann fuses. This is how my Alternators voltage regulator controller is going to be wired up, all new components for a piece of mine.
Bought some new RCAs from the SSA Store. The Audison one's are too bulky and just don't make my install look so appealing but otherwise they are great. The Stingers don't make good contact, if you turn them some or install them a certain why it drops some of the signal.
I'm trying to make it look as factory as possible and protect the wires for the alternator voltage regulator going into the engine bay.
These Rhyno RCAs seem to be dope so far, the connection is tight and the color scheme is real nice. They look perfect in their new home, thanks SSA.
There's no turning back now, the 8"s have arrived. It's time to get these front doors fondled and customized for a pair per door :woot: :rockwoot:
Old Faital Pro 6PR160 vs New Stevens Audio MB8-2
