Cleaned up the front stage 6 channel amplifier wiring
  • Replies 401
  • Views 56.5k
  • jcarter1885
    jcarter1885
    Some of the equipment from the previous build and wires since I always buy extra to have. Enclosure should be done either this week or next week and Im still waiting on the sub but no biggie until I g
  • jcarter1885
    jcarter1885
    Sound deadening has began
  • jcarter1885
    jcarter1885
    I'm 80% done with the sound deadner, the trunk deck is next. I didn't do the under side yet because I don't feel like uninstalling the factory subwoofer till it blows or until my new Fi sub gets here.
The small subtle things stand out the most
On 10/4/2021 at 11:44 AM, Tirefryr said:
Need to illuminate them.  :blink:
I would but the blue lights from above, light it up perfectly. I need to find a different filter because my camera makes everything appear blue which it doesnt do looking at it in person.
Edited by jcarter1885
New Battery Terminals from Jim's MachineWorx for my front battery. You will see why I need these later on, probably this weekend if I start on the big 3 wiring.
When you buy battery terminals and the whole is too small for the bolt, just bring out the drill and get to work
VW wiring terminals suck as they do not allow you to take off the nut to allow more terminals to be added. No biggie as I can easily replace it. I actually love their grounding points, pretty effin dope of you ask me. The nut that holds the wires is back but the underside that meets the terminals is bare metal.
Big 2 of 3 wiring is complete plus factory wire upgrade for the negative side, all 3 wires are 2/0 welding cable. The positive side is going to be a whole different animal.
I like twins even if one is bigger than the other one. Love these batteries, the new underhood group 48 battery came resting at 12.96volts.
Factory battery was a group 43 but it had extra room left in the battery tray and seen a video on YouTube where a dude had a group 48 battery so I said F it and went bigger. New battery fit with no issues whatsoever.
Voltage with Max AC and other features on now sits at 14.3v vs 13.8v with the factory battery in.
Quick run to the store after the cold front came through and I have some healthy voltage.
On 10/19/2021 at 5:30 PM, Tirefryr said:
I can't see if you have it on there, but put some anti-oxidant like Noalox inbetween the copper lugs and aluminum buss to prevent galvanic corrosion.  I'll have to look into these batteries.
No I didn't know that so thanks for the heads up. I will get some this weekend.
It looks like my idea may work to allow me to keep factory positive terminal intact while using my new battery distribution block.
  • 2 weeks later...
A gift from my friend who got me started into installing systems back in 2007, I sent him a card package earlier this year and he returned the favor. Love true friends because a battery charger has been on my list for years and I never took the leap. I knew I kept that VW wire for a reason since they ask you not to connect the negative charging clamp to the negative battery terminal.
This Odyssey which is my trunk battery has been unhooked since the day (June 12) after my wreck and it still rests at 12.56 v but it needs to be maintained.
Drilled the hole for the trunk ground wire in the spare tire well.
Sanded off the paint and I also cut a channel in the foam lining of the spare tire support to allow the ground wires lay flat under the carpet.
I finally got some @Tirefryr, thanks again for the insight.
17 hours ago, Tirefryr said:
Use that on the ground wire too between the copper and steel.
Do i need a lot or just a little but underneath? Does it ever dry up and need to be reapplied? sorry for all the questions.
You just need a light layer.  It won't dry up.  It's basically just grease.  It will attract dirt obviously, but will keep any corrosion at bay.  I literally buy small paintbrushes from the dollar store, like water paint brushes, and use that to apply between the metal and the terminal and then I'll lightly coat over the terminal itself so it doesn't corrode.
Ok one last question do I do it on the grounds in the trunk? Will I have to still spray paint over to reduce the metal from rusting in the areas I sanded the paint down? Or can I just cover it with a layer of this and be ok?
Thanks man
