Posted April 12, 200719 yr I have an ava 15 ... and i wanna know what kind of power i should put to it ... right now i have a kx1200 that i could run to it but im afraid with that power in 2.5 sealed enclosure it might be to much ... any suggestions? maybe a dif amplifier?
April 12, 200719 yr i'd go with 800, hell i could power my tweets off that amp, its not about the power, it's about setting your gains properly and being careful with the volume.
April 12, 200719 yr I have an ava 15 ... and i wanna know what kind of power i should put to it ... right now i have a kx1200 that i could run to it but im afraid with that power in 2.5 sealed enclosure it might be to much ... any suggestions? maybe a dif amplifier?Go down to 2.0 cubes even and you'll be fine. Thermal power handling is not the issue here; it's keeping it within mechanical limits.
April 12, 200719 yr Author thats what i was thinking ... for now i might keep it in the 2.5 til i can get a new box ... looking at 4.0 tuned to 28-30 hz since the fs is low
April 12, 200719 yr thats what i was thinking ... for now i might keep it in the 2.5 til i can get a new box ... looking at 4.0 tuned to 28-30 hz since the fs is lowThe 18s are a bit heavier than the 15s, but I fed my Avalanche 18s 1300+ each for over a year and never once bottomed them out.Of course, it wasn't a constant 1300 because its music, but clipped or unclipped, they got 1300 frequently wether they liked it or not. Edited April 12, 200719 yr by Duke
April 12, 200719 yr i have run both the bx1000d and bx1500d from hifonics to my 15ava. in a 4cuft 28hz box. the 1500d wired at 1ohm seemed to be a little much for it at a high volume. it starts to make a funny smell. the 1000d (curently using) seems to be a much better fit. i can play it as loud as i can tolerate for extended amounts of time with no problems at all. hope this helps....
May 19, 200719 yr I run 1500 to mine daily with no problems whatsoever. Have never bottomed it either.
