Posted June 22, 200718 yr i just got in my 18 btl and had it prof installed 5 min into ownin it it blew so i need a recone who do i need to email i emailed shawn and scott multi times with no reply its been a few days?
June 22, 200718 yr i just got in my 18 btl and had it prof installed 5 min into ownin it it blew so i need a recone who do i need to email i emailed shawn and scott multi times with no reply its been a few days?How did they set the gain? A BTL is pretty damn hard to kill, what amp are you using?
June 22, 200718 yr i just got in my 18 btl and had it prof installed 5 min into ownin it it blew so i need a recone who do i need to email i emailed shawn and scott multi times with no reply its been a few days?Something must be completely wrong.5 min.......is that a record for any Fi? Mad would'nt even explain it!
June 22, 200718 yr What is your email address? I dont think Ive seen anything or responded to anything about a BTL smoking in 5 minutes...Whats your setup like?Thanks,Scott
June 23, 200718 yr Author i feel like a tool i think i was emialing the wrong address i got your right one off the ecoustics i emailed you thnx for the help
June 24, 200718 yr Author [email protected]\What is your email address? I dont think Ive seen anything or responded to anything about a BTL smoking in 5 minutes...Whats your setup like?Thanks,Scott
June 24, 200718 yr Author i think sumthin might be wrong with me email so i thought id get ahold of you on here i need a recone for my btl 18 after 5 mins of having it a vc popped
June 24, 200718 yr What kind of power were you throwing at that to blow it? was it on 2 amps- one per coil?What amps and enclosure?
June 24, 200718 yr i think they sent it an ungodly clipped signal. are you sure they were "proffesionals"?
June 25, 200718 yr i think they sent it an ungodly clipped signal. are you sure they were "proffesionals"?I agree with flakko...Just cause it's a car audio shop doesn't make them professionals...
June 25, 200718 yr i just got in my 18 btl and had it prof installed 5 min into ownin it it blew so i need a recone who do i need to email i emailed shawn and scott multi times with no reply its been a few days? The only possible way I can think of that he blew up a btl in 5 minutes would be with two severely clipped signals and the voice coils wired backwards. Which shouldn't happen with "professional installation" We are all curious as to how you managed to kill a sub that could probably out last a circuit breaker on a wall outlet.And need I restate my point... Edited June 25, 200718 yr by audio-neon
June 25, 200718 yr I don't think YOU blew it in 5mins.Either the "Professionals" were screwing around with the sub (or you, or both)...or there's something we don't know.What amp did you blow this BTL with? What HU? ....and maybe some info about the offending shop.
June 26, 200718 yr I would also like to know what amp were you using? How was it wired? What were the gains set to? I have a BTL in the garage that I was using for burps, that was seeing 1 SAZ1500D to each coil for about 3K W total, and I was unsuccessful @ trying to overpower it. Either your signal was clipped, or the "asshat's," that did your install were about as useful as an infant with a DMM. I also hope you realize that the BTL's don't come with a warranty due to their ridiculous power usage.
June 26, 200718 yr why in all these blown threads the poster only has like 5-10 post total, mostly from there own thread?
June 26, 200718 yr why in all these blown threads the poster only has like 5-10 post total, mostly from there own thread? Normal members that don't want anyone to know they fudged up?
June 26, 200718 yr Wow, one thread not enough?not only that but he has YET to explain his claim of it blowing in 5 mins which i think is a total crock of chit..../thatisall
