Posted October 14, 200917 yr So my next install will consist of 2-saz2000 and 2-15inch NS d2and i was wondering how much AH i should have on my batteries to support my 2 saz2000 straped at 2ohm?i know i read somewhere that if it is at 1ohm just take the fuse size and divide it by 2 and there you go! so for 1 saz2000 at 1ohm i would need a mini of 100ah battery to support it!now i am wondering, i got a good deal on some nsb 90 (90ah) and i can't pass up the deal but they are only 90ah each and i want to get 2 of them. now will this 90ah (180ah total) be enough to support 4krms at 2ohm? thanks for your timeKenneth
October 15, 200917 yr Author i think i found my answer! can someone please confirm this site? http://cr4.globalspec.com/thread/32655/How-to-calculate-the-required-AH-for-upsalso i jsut worked it out and here is what i got!200amp(current)X 0.25(about 15mins of play time) = 5050/0.9= 55.5555.55/0.5=110so i will need 110ah per amp? i think that is wrong though but i need someone to confirm my finding or someone who knwos what is going onthanks for your timeKenneth
October 15, 200917 yr I am pretty sure it is calculated without a charging source. You have an alt that will charge those batts and you will also not be drawing that much current at a constant rate.
October 15, 200917 yr Author good point! i never thought of that before~ thanks for bringing that into perspective!so since i have a h/o (200amp alt) i guess i can use 2 nsb90's for 150 each!!! sweet!thankyou so much!! you rock man! Edited October 15, 200917 yr by CrazyKenKid
October 17, 200917 yr So my next install will consist of 2-saz2000 and 2-15inch NS d2and i was wondering how much AH i should have on my batteries to support my 2 saz2000 straped at 2ohm?i know i read somewhere that if it is at 1ohm just take the fuse size and divide it by 2 and there you go! so for 1 saz2000 at 1ohm i would need a mini of 100ah battery to support it!now i am wondering, i got a good deal on some nsb 90 (90ah) and i can't pass up the deal but they are only 90ah each and i want to get 2 of them. now will this 90ah (180ah total) be enough to support 4krms at 2ohm? thanks for your timeKennethI would say yes that 90Ah will be ok for the 2-SAZ-2000D's but if you go to a competition or try to pound at full tilt for a while it may be a small factor (but it depends since music is dynamic). I would suggest upgrading your starting battery to give you that extra AH if worried about it or it becomes a problem since you can get those batteries cheap.
October 17, 200917 yr Author So my next install will consist of 2-saz2000 and 2-15inch NS d2and i was wondering how much AH i should have on my batteries to support my 2 saz2000 straped at 2ohm?i know i read somewhere that if it is at 1ohm just take the fuse size and divide it by 2 and there you go! so for 1 saz2000 at 1ohm i would need a mini of 100ah battery to support it!now i am wondering, i got a good deal on some nsb 90 (90ah) and i can't pass up the deal but they are only 90ah each and i want to get 2 of them. now will this 90ah (180ah total) be enough to support 4krms at 2ohm? thanks for your timeKennethI would say yes that 90Ah will be ok for the 2-SAZ-2000D's but if you go to a competition or try to pound at full tilt for a while it may be a small factor (but it depends since music is dynamic). I would suggest upgrading your starting battery to give you that extra AH if worried about it or it becomes a problem since you can get those batteries cheap.thankyou so much for your reply! and i will take your recommendation to upgrade my head battery and i can get the nsb 90's for 150 each in canada just incase someone was wondering how cheap. and i don't mean to be a dick or rub it in.
October 22, 200917 yr Author FOUND IT~~~!!!~~~http://www.youtube.com/MaxxsonicsUSAInc#p/u/2/H5MP5F-uJAwenjoy!
