Posted November 17, 200916 yr I was wondering if you think it would be better to get a 1000 or 1200 for a daily driver. I'm putting them on 2 15 BL's ... any idea's on this? the pro's cons to both?
November 17, 200916 yr I was wondering if you think it would be better to get a 1000 or 1200 for a daily driver. I'm putting them on 2 15 BL's ... any idea's on this? the pro's cons to both? , please give out more information. Whichever one you can afford and fits within your power needs. Either one will do your system justice, one amp per sub or one amp for both subs?
November 17, 200916 yr Wont be much of an audible difference between 1000 and 1200 watts. The mic would notice but your ears probably wouldnt.
November 17, 200916 yr go with what is cheaper!! b/c 200rms is't going to be much on the ear! the only neg is with the 1200 you will be drawing more currnet draw (more power) lol!
November 18, 200916 yr Author sorry for the lack of information. I was at class when I first posted. I have 2 15 Fi BL's ,DVC,1 ohm IIRC ... I just want to hook both of them up to one amp @ 1ohm. I know they can handle more, but I got jacked a couple months ago and need a good buy. Mainly I just want the most reliable for a daily. I hope this information helps, If I need to put more just let me know.Josh
November 18, 200916 yr sorry for the lack of information. I was at class when I first posted. I have 2 15 Fi BL's ,DVC,1 ohm IIRC ... I just want to hook both of them up to one amp @ 1ohm. I know they can handle more, but I got jacked a couple months ago and need a good buy. Mainly I just want the most reliable for a daily. I hope this information helps, If I need to put more just let me know.JoshWell what kind of budget are you working with?
November 18, 200916 yr Author sorry for the lack of information. I was at class when I first posted. I have 2 15 Fi BL's ,DVC,1 ohm IIRC ... I just want to hook both of them up to one amp @ 1ohm. I know they can handle more, but I got jacked a couple months ago and need a good buy. Mainly I just want the most reliable for a daily. I hope this information helps, If I need to put more just let me know.JoshWell what kind of budget are you working with?350-400 is the most I want to spend, Like I said I got robbed so I have been slowly adding money to the "car audio" fund Edited November 18, 200916 yr by JoshM20
November 18, 200916 yr sorry for the lack of information. I was at class when I first posted. I have 2 15 Fi BL's ,DVC,1 ohm IIRC ... I just want to hook both of them up to one amp @ 1ohm. I know they can handle more, but I got jacked a couple months ago and need a good buy. Mainly I just want the most reliable for a daily. I hope this information helps, If I need to put more just let me know.JoshWell what kind of budget are you working with?350-400 is the most I want to spend, Like I said I got robbed so I have been slowly adding money to the "car audio" fundYou probably need to put that money towards an alarm system first, but either amp will be justice. Also check out the amps at db-r.com and get a SAZ-1500D refurbished.
November 18, 200916 yr If you want to go with something cheap right now then look at this.http://www.soundsolutionsaudio.com/store/products/Sundown-Audio-SAE%252d1200D.htmlBut if you can save a little more then look at this.http://www.soundsolutionsaudio.com/store/products/Sundown-Audio-SAZ%252d2000D.htmlBut this is perfect. Edited November 18, 200916 yr by bigrank916
November 18, 200916 yr Author Thanks Guys, Yea I have already put in an alarm/new dash/cd player... So amp is the last thing I need to get again.
November 18, 200916 yr Thanks Guys, Yea I have already put in an alarm/new dash/cd player... So amp is the last thing I need to get again.No problem and be more wise on how you bump your music and where you bump your music.
