Me personally do not like threads like the one i am making currently.. but i just need suggestions for my brother.
He's getting (2) 15" BTLs for a 99 Dodge Dakota RT.
I need amp suggestions, either.. (2) 2k amps that can be strapped OR (1) 4k amp
The amps can be around 2k or 4k.
We've thought about AQ2200 and SAZ-4500D
Thanks, BanginGMC.
crescendo audio 3kwp
4k at .5 ohms at 13.8 volts
No amps under 1ohm, but thank you.
well if he can achieve the higher voltages then he can do 4k at 1 ohm 16 volts
but no problem just throwing some ideas out there
Theres a Memphis mojo 4kw on my local CL for 500.
Thanks, BanginGMC.
i would go with one aq3500 it will do 4300 at 1ohm
i've had 2 Memphis 4kws before and loved them, a little on the pricey side but def. worth the extra coin, i swapped from two of those to 2 goliaths and regret it. The memphis dont get as hot, cleaner signal, and overall better amp. they def. do the power they say they do
how about 2-SAZ2000's?
also do you have a budget?
AQ3500... hmm, I think we have a winner.
Keep the suggestions coming if possible.
Leave budget out of suggests guys, thanks.
All amps are accepted :)
Are you kidding? There are way too many options without budget. You can go with any decent brand and can get two 2ks or a 3.5-5k amp.
stetsom 4k
Second.
I think we're going to go with the AQ3500, and no.. i wasn't kidding :)
well aq has been good to you in the past...not a bad choice at all
True, I wish Alpine made PDX amps that do 4500krms + as many filters as AQ
speaking of pdx.....i think im going to pick up a pdx 4.100 after i get 2 sets of type x components
Don't get the PDX4.100
Get the PDX-F4
Why no below 1ohm? Makes your search alot easier.
Because i like to make things complicated :)
No, but it's easier on the amp if it's 1ohm instead of .5 so.. thats why.
AQ is the winner.
