Posted October 29, 201015 yr Popular Post Ascendant Audio Carbon Fiber MidsHey there. I figured I would make this thread to clear some info up, since these questions seem to come up a lot about these. I received mine in the mail today and started to take pictures and measure right away.If you want to know anything else that I don't state about them, let me know and I will do my best to answer them.1.) What size are they? The outer diameter of the whole driver is JUST under 7", but that may be my tape measure. The mounting ring is 1/2" wide, which leaves 6" for cone+surround. Surround is another ~1/2" so the cone is ~5" from the inside of the surround to the other side.2.) What's the mounting depth? From the bottom of the magnet to the top of the frame it is JUST under 3.5". The mounting plate is ~3/16".3.) What is the voice coil resistance? The carbon fiber mids are rated at 4 ohm, each. I don't know if it's just my meter or what but when I measured this they were down to about 2 - 2.5 ohm. I think it was coincidence I happened to take the picture right at 3.9 ohm.4.) What's a good frequency range? That's going to depend on install a bit, but I see them run around 60-2500 (ish) mostly, so that's where ill start my setting at. We will see when I get them installed.5.) How much do these run?You need to contact a dealer to get some of these, or even a price quote. You can go HERE to contact them and find a dealer. I bought mine from SSA user BKOLF04. You can also pm him and he can tell you if there is a closer dealer to you or not.Let me know what else you want to be measured or what not. Video of when I still had these.
October 29, 201015 yr Bet you are excited to get these in the car! I was going to get a video up sometime for you, but I guess you won't need me to lol.
October 29, 201015 yr Author Bet you are excited to get these in the car! I was going to get a video up sometime for you, but I guess you won't need me to lol.The only reason i asked was because i was getting antsy! But I'm still trying to figure out what I'm going to do to get these in my door. I believe I have the right idea, just needs some skillz to get done!
October 29, 201015 yr They are some GREAT sounding mids. They get very loud and play very clear. I keep up with the bass pretty darn good!
October 29, 201015 yr Thanks for sharing info on your new products!!! Great that you included measurements, that is good info!!!!
October 29, 201015 yr Author They are some GREAT sounding mids. They get very loud and play very clear. I keep up with the bass pretty darn good!I can't wait to install them! Thanks for sharing info on your new products!!! Great that you included measurements, that is good info!!!! Thanks!
October 29, 201015 yr I had a pair of Exodus Audio 6.5/7s like those ... sounded Great !!! they should go lower than 60 htz, mine played great around 40. They have cool excursion ...
October 29, 201015 yr Let me know how 60 hz goes. My RE xxx comps love it low and these are the only mids right now I'm considering witching to. Cant wait for a vid
October 29, 201015 yr Let me know how 60 hz goes. My RE xxx comps love it low and these are the only mids right now I'm considering witching to. Cant wait for a vid Fink ill have a pair to play with soon if you want to meet up somewhere and we can try them out
November 2, 201015 yr Yes please, make a video from 60hz-200HzIm planning on using two pairs or maybe three as mids AND midbass. I dropped plans to use an 8" driver on each front door when I found out this could go as low as 50Hz (Nick has them at 50Hz).He also mentioned carbons can actually go up to 5000Hz, but Im pretty sure most people should find 2500-3000hz the sweet spot.
November 2, 201015 yr Author Yes please, make a video from 60hz-200HzIm planning on using two pairs or maybe three as mids AND midbass. I dropped plans to use an 8" driver on each front door when I found out this could go as low as 50Hz (Nick has them at 50Hz).He also mentioned carbons can actually go up to 5000Hz, but Im pretty sure most people should find 2500-3000hz the sweet spot.I'm waiting on my order from SDS and a couple other little things to tie everything in before i can install them. HOPE it can be done this weekend. *crosses fingers*My CLD tiles and butyl rope wont be here for a week. so next weekend hope to have everything in.
November 2, 201015 yr Yes please, make a video from 60hz-200HzIm planning on using two pairs or maybe three as mids AND midbass. I dropped plans to use an 8" driver on each front door when I found out this could go as low as 50Hz (Nick has them at 50Hz).He also mentioned carbons can actually go up to 5000Hz, but Im pretty sure most people should find 2500-3000hz the sweet spot.I'm waiting on my order from SDS and a couple other little things to tie everything in before i can install them. HOPE it can be done this weekend. *crosses fingers*Dont rush Will keep an eye on this thread
November 3, 201015 yr Author I have t/s parameters now. . . :-)are you able to post them/ give them to me to post?
November 28, 201015 yr Author Updated with smaller pics. Another big "Thank You" to Sefugi. This page should load much quicker now, getting your info in a fraction of the time. I'll work on a vid. tomorrow of them.
December 15, 201015 yr At long last I finally got my mids and tweeters installed, albeit running off Phoenix Gold passive crossovers but god damn they are nice, I've heard all sorts of others and to be honest so far these would have to be right up the top of the list, once they have had a bit of use and I get some more cable to run them active I'll give it a good tune and no doubt get them even sweeter. I've had them sitting here for about a year!!
December 12, 201114 yr Ive seen these run full range and sounded awsome of course I would not recommend it unless you are careful with what you are doing... Own two sets my self they are awsome mids and for those who are wondering if installed properly they will play lower than 50 hrz just as Mark we had lots of fun listening to them!!
January 15, 201214 yr Author I know this is an old thread but how did you like the resultsSorry for such the late reply, haven't been on in a while.I sold these a while ago. Was pretty darn impressed with them, while never giving them the power they wanted. I wish I still had them actually.. As stated they're sold out. Very nice mids.Added a video of these playing on the first post.
