Posted March 16, 201115 yr is the sundown 1500 .5 ohm stable?? for daily use? Using it for 2 15" SSA Icons
March 16, 201115 yr What coils do your icons have? And your planning on switching to xcons and wiring to .5?In my honest opinion, don't be cheap and run it at .5, if you need 3000watts buy a 3000d.And if you do end up running it at 0.5 you better have a good electrical setup.
March 16, 201115 yr Can it be done? Yes. Should it be done? Probably not. Can you do it? That we don't know. For daily you shouldn't run your amp that low unless you really know what you are doing and know you have the electrical support for it. Get a second and strap them if you are already stuck on that load.
March 16, 201115 yr I'm not sure about the V2s, but the V1s can do it with proper electrical. But I have some doubts that the OP will upgrade his electrical.
March 16, 201115 yr I'm not sure about the V2s, but the V1s can do it with proper electrical. But I have some doubts that the OP will upgrade his electrical.Gotta have to make
March 16, 201115 yr I'm not sure about the V2s, but the V1s can do it with proper electrical. But I have some doubts that the OP will upgrade his electrical.Gotta have to make Yes and to me the OP is just skimping out of buying a 3000watt amp.I also know distortion will rise a bit, not sure if it'll be audible or not.To me this is like buying a subaru wrx, adding a mbc and boosting it from the stock 14.5psi to 25psi and going YIPPIE I'm race ready!
March 17, 201115 yr I beleive the V1's were stable @ .5 ohm but not the V2'sThe v.2 does everything the v.1 does.
March 17, 201115 yr I beleive the V1's were stable @ .5 ohm but not the V2'sThe v.2 does everything the v.1 does.I stand corrected. Thank you.
March 17, 201115 yr I'm not sure about the V2s, but the V1s can do it with proper electrical. But I have some doubts that the OP will upgrade his electrical.Gotta have to make Yes and to me the OP is just skimping out of buying a 3000watt amp.I also know distortion will rise a bit, not sure if it'll be audible or not.To me this is like buying a subaru wrx, adding a mbc and boosting it from the stock 14.5psi to 25psi and going YIPPIE I'm race ready!Hey, hey! Not everyone can get their hands on an STI
March 17, 201115 yr I'm not sure about the V2s, but the V1s can do it with proper electrical. But I have some doubts that the OP will upgrade his electrical.Gotta have to make Yes and to me the OP is just skimping out of buying a 3000watt amp.I also know distortion will rise a bit, not sure if it'll be audible or not.To me this is like buying a subaru wrx, adding a mbc and boosting it from the stock 14.5psi to 25psi and going YIPPIE I'm race ready!Hey, hey! Not everyone can get their hands on an STIYour an idiot.
