is the sundown 1500 .5 ohm stable?? for daily use? Using it for 2 15" SSA Icons
Yes but it voids the warranty.
What coils do your icons have? And your planning on switching to xcons and wiring to .5?
In my honest opinion, don't be cheap and run it at .5, if you need 3000watts buy a 3000d.
And if you do end up running it at 0.5 you better have a good electrical setup.
I beleive the V1's were stable @ .5 ohm but not the V2's
Can it be done? Yes. Should it be done? Probably not. Can you do it? That we don't know. For daily you shouldn't run your amp that low unless you really know what you are doing and know you have the electrical support for it. Get a second and strap them if you are already stuck on that load.
I'm not sure about the V2s, but the V1s can do it with proper electrical. But I have some doubts that the OP will upgrade his electrical.
Gotta have :morepower1: to make :morepower1:
Yes and to me the OP is just skimping out of buying a 3000watt amp.
I also know distortion will rise a bit, not sure if it'll be audible or not.
To me this is like buying a subaru wrx, adding a mbc and boosting it from the stock 14.5psi to 25psi and going YIPPIE I'm race ready!
The v.2 does everything the v.1 does.
I stand corrected. Thank you.
Hey, hey! Not everyone can get their hands on an STI
Your an idiot. :bigok:
