Posted April 10, 201114 yr Dear SSA techies,I am going to be running my 15" XCON in a ~2.5^3ft sealed enclosure. I am curious if when the 15" ZCON is available will I be able to do a direct swap in my sealed enclosure? Thanks,edub
April 10, 201114 yr Admin The Zcon will not be getting sealed enclosure designs. It is intended for higher power, ported enclosure arrangements.
April 20, 201114 yr ported>sealedAcutually thats not the case unless your systems goals are designed around a ported enclosure then yes your correct.Zcon subs are meant to be played in ported enclosures only, so in this case you would go with a ported enclosure.
April 20, 201114 yr ported>sealedDepends on the goals, usage, personal preference. I personally enjoy a ported box as i like more bass. As to OP as stated by Aaron the ZCON's are not designed for sealed enclosures they are meant for high power and heavy bass. I would like to hear how the XCON sounds in a sealed enclosure.
April 20, 201114 yr Author ported>sealedDepends on the goals, usage, personal preference. I personally enjoy a ported box as i like more bass. As to OP as stated by Aaron the ZCON's are not designed for sealed enclosures they are meant for high power and heavy bass. I would like to hear how the XCON sounds in a sealed enclosure.You guys really are beating a dead horse.Denim, owner of SSA, answered my question in it's entirety nearly two weeks ago.Any further discussion will either be redundant or off topic.
