that thing looks sweeeeeeeet. :twirl:
  • Replies 111
  • Views 20k
  • Going way off topic here but......... Everytime i see you avatar "The enD" I end up staring at it for like 10mins till i realize i have been lost in the sight of breats!!! ANYWAYS, back to our regular
  • ford302redneck
    ford302redneck
    Jake, I think you should send me this sub in a 18in and a NS-1 to test. I'll pay shipping.
  • holy crap
Forgot to bring the pics over here from the Facebook :
Attached to 15" frame.
If we do make it the shorting rings (three of them) will be aluminum.
that looks KILLER!!!
We are working out the coil details still -- making it longer than the original is going to be challenging for a D1 coil :)
  • 1 month later...
Looking forward to these!!
Is it just the photo composition or is that coil REALLY thick!?
Is the driver designed to compliment the NS-1?
That is great!!! I think they will need about 2 NS-1 to power this bad boy, and maybe 4 to get it to a full power potential!!! I might be over exaggerating, but these things aren't designated as "monsters" for nothing!!
It really is that thick.
D2 is together... specs are closing in on where I want to be -- based on what I got from this D2 I think the D1 coil should be correct out of the gate and that the D2 will be good with a tad bit of tweaking :
D2 Revision 1 Coil Specs with 5-layer Z v.3 spider (Z v.3 uses 4 layers) :
RE : 2.93 ohms (series)
FS: 36.87 Hz
QES: 0.329
QMS: 4.326
QTS: 0.306
LE: 6.53 mH (still a bit high but we'll work on the shorting rings on another prototype to get this down)
VAS: 43.24 L
BL: 28.128 NA
MMS: 383 g
CMS: 48.56 uM/N
SENS: 89.93 dB 1w/1m
BL^2/RE: 270 (goal is 300 or so for this driver... revised coil should do it)
I'll do some beating on it soon... have tons of SA-8s to ship... took a short break to pull specs and post them.
That looks loud as balls!!!
That's off the wall. You are going to do some damage with that thing. :morepower1:
  • 3 weeks later...
that thing is loud just sitting there, PUT IT ON SOME POWA! :rofl2:
edit: forgot to mention, when i saw the thickness of that coil, my jaw literally dropped, shit is insane.
Edited by ChevyBoy95
was expected coninuous load on these things mentioned ...
what will these coils take ?
  • 1 month later...
I am working on baskets before bringing out a motor this heavy.
  • 2 months later...
YES!!!
