  • Replies 329
  • Views 50.4k
  • basshead7890
    basshead7890
    finish up the new panel for the amps today, and i'm going to make a piece up cover up the gap i still have to repaint the port
  • basshead7890
    basshead7890
    i just finish painting coat of latex paint in port, im going to put another coat tomorrow and i still have to try to get that wrinkle out of the rear deck cover and make a panel for the gap
  • basshead7890
    basshead7890
    now I just have to put everything back together
looks good! Im guesing you have all that sound proccesing because your runnin a tablet?
nice subwoofer bro, so are gonna try and port the 18 in your car? man i wish i had 3 more cubes in my trunk to do 2 15's or an 18 haha
I want to, i just don't have enough room, but if i can come up with a design i will try tho.
i just have a 3.5mm cord to rca and i hook it up to the aux on my equalizer
  • Admin
Is that a Nook?
Is that a Nook?
Nook Color tablet for head unit
Nope :P
  • Admin
Is that a Nook?
Nope :P
:Doh: I never glaze over, oh well case of the Monday's. My mother has a Nook, nice little tablet. :)
Refurbished saz1500 from db-r, it came in the 3 days. "It's your lucky day, we had gotten an extra 1500dv2 in our last refurb order from Sundown, so yours is going out 6-9 days before schedule. Tracking says you will have it Friday. Thanks!"
the sundown felt heavier
at 2 ohms it sounded louder then the brz at 2 ohms, and now i have it wired at .5 ohms and i my voltage drops to 10 at 4 clicks on the bass knob also i'm going to add another battery
Edited by marq7890
I would go back to 2 ohms or keep the volume/gain down until you get the other battery just to be safe.
Looks Good!!!
I was thinking only the V1s were .5 stable, for a dd I would suggest running the amp at 2ohm as well even with the rear bat.
Looks Good!!!
Yeah man get outta that 0.5 ohm unless you have a ho alt! A rear batt might keep you in the 12-13v range but that's it, some people are happy with that.
  • 3 weeks later...
homemade fuse block
shuriken bt-20
now with the second battery my voltage drops to 13 with head lights on and ac at full blast wired at 2ohms
Edited by marq7890
  • 2 weeks later...
Saw the Alabama blanket/rug/whatever it is, where you from?
Huntsville too
  • 2 weeks later...
I was driving and a wire came loose and it stop playing. When I reconnected it, it still didn't work. I'm either going to get it reconed or get it change to a 15" d2
Edited by marq7890
