August 7, 201115 yr nice subwoofer bro, so are gonna try and port the 18 in your car? man i wish i had 3 more cubes in my trunk to do 2 15's or an 18 haha
August 7, 201115 yr looks good! Im guesing you have all that sound proccesing because your runnin a tablet?
August 7, 201115 yr Author nice subwoofer bro, so are gonna try and port the 18 in your car? man i wish i had 3 more cubes in my trunk to do 2 15's or an 18 hahaI want to, i just don't have enough room, but if i can come up with a design i will try tho.
August 7, 201115 yr Author looks good! Im guesing you have all that sound proccesing because your runnin a tablet?i just have a 3.5mm cord to rca and i hook it up to the aux on my equalizer
August 15, 201115 yr Admin Is that a Nook? Nook Color tablet for head unitNope I never glaze over, oh well case of the Monday's. My mother has a Nook, nice little tablet.
August 20, 201114 yr Author Refurbished saz1500 from db-r, it came in the 3 days. "It's your lucky day, we had gotten an extra 1500dv2 in our last refurb order from Sundown, so yours is going out 6-9 days before schedule. Tracking says you will have it Friday. Thanks!"the sundown felt heavier at 2 ohms it sounded louder then the brz at 2 ohms, and now i have it wired at .5 ohms and i my voltage drops to 10 at 4 clicks on the bass knob also i'm going to add another battery Edited August 20, 201114 yr by marq7890
August 20, 201114 yr I would go back to 2 ohms or keep the volume/gain down until you get the other battery just to be safe.
August 20, 201114 yr Looks Good!!! I was thinking only the V1s were .5 stable, for a dd I would suggest running the amp at 2ohm as well even with the rear bat.
August 20, 201114 yr Looks Good!!! I was thinking only the V1s were .5 stable, for a dd I would suggest running the amp at 2ohm as well even with the rear bat.Yeah man get outta that 0.5 ohm unless you have a ho alt! A rear batt might keep you in the 12-13v range but that's it, some people are happy with that.
September 7, 201114 yr Author homemade fuse block shuriken bt-20now with the second battery my voltage drops to 13 with head lights on and ac at full blast wired at 2ohms Edited September 7, 201114 yr by marq7890
September 19, 201114 yr Author Saw the Alabama blanket/rug/whatever it is, where you from?Huntsville too
October 6, 201114 yr Author I was driving and a wire came loose and it stop playing. When I reconnected it, it still didn't work. I'm either going to get it reconed or get it change to a 15" d2 Edited October 6, 201114 yr by marq7890
