Now, Im not sure if this is actually done very often but it seems like a lot of laziness to me. Here is what my local shop did back when my dad first got the speakers installed.
They simply spliced into the old connectors for the OEM speakers instead of just running new wire from front to back. But anyways, Im in the middle of rewiring anways so I guess i just need to cut those connections and tape up the loose ends for now.
Alright, could be :) I just feel better running wire from front to back, instead of going through like 3 different connectors, Id rather have a new and solid path.
If you amped your speakers, you wouldn't have this issue anywho gayhaaay1.gif
x2
Meh
Alright, just a noob mistake by me then, but what im saying is that I do have an amp for my speakers, they arent being run of the HU, they ran the wires from that connector all the way back to the amplifier. (If there was any confusion)
Why would you rerun wire? If it's not broken, why fix it?
IMO it's perfectly acceptable when it's a PITA to go through the conduit in the door.
I agree. Also less labor if the customer is on a budget.
There are new wires from the from to the back. The wires are tapped into the factory harness running to the amp. If they ran completely new wire to each door you would mire than likely complain about a 250 dollar amp install.
I am a little confused... still lol
What I am looking at, in this photo, is from the wire harness, is wired to what seems to be speaker wire, which I'm assuming is running to your door speakers. Now, if your door speakers were indeed amp'd, then you wouldn't be using the wire harness, period.
Ok Sencheezy instead of tuning new wire to the doors they cut the stock speaker wire behind the radio, tied new wire to it and ran that new wire to the amps. So the power goes from the amp, through the new wire and then through the stock wire to the doors.
I would never do it that way but if that's all you paid for then....
Ok, so mike, when you said that they are amp'd, do you mean factory amp or after market amp?
I have an aftermarket amp, a PG Ti500.4, the reason they went through that connector is so they could bypass running wires through the door grommets, the just spliced into the factory wiring connector.
I use the factory wiring into the doors when adding a small highs amp. Once it passed the 100w per speaker point though, I run all new wire. and charge about $40-$60 more. lol
Well, because I did it all myself it cost me close to nothing :) It looks great, much cleaner, and I actually know what all my wires DO this time. :P
most times even when amping i use the OEM wire..... and tape is VERY VERY good..... when used correctly.. ALOT of people have NO clue how to use it.... they just wrap it in the black and call it done..... nothing could be further from correct...
electrical tape must be stretched while applied
