All,
I am looking into running 2) SA-12s in my 2012 Volkswagen Jetta GLI. I do not want to loose my entire trunk with a large ported enclosure and also, I prefer the sound of sealed enclosures. I am not a SQ freak but I like the tight bass, with some boom if I crank it up. I am limited to 1000-1200W RMS.
They will be getting 600W each @ 2 Ohms. My question is this - the Sundown website recommends 1.0 ft^3. I listen to mostly rap, R&B, electronic, with some metal mixed in there.
1) Should I be going slightly larger than recommended to retain my lows (e.g. 1.25 ft^3)?
2) I can't find much info on the SA-12s in sealed enclosures. Anybody running these sealed? How do you like them?
3) Any other recommendations if these are not the right subs for me?
I'm looking for a nice pair of subwoofers around the $200-250 price range each, with 500-600W RMS each, decently loud sound in a sealed enclosure. Other drivers I have considered but decided against for one reason or another:
1-15" FI-Q Sealed @ 1000W ((I figured the displacement of the 2 SA-12s would better suite my taste))
1-15" SSA GCON Sealed @ 750W ((If only the GCONS were 600W RMS so I could run 2 of them in a sealed enclosure))
2-12" Type-Rs Sealed @ 1000W ((i've always had shit luck with Alpine))
2-12" JL W3s Sealed @ 1200W ((I was immediately turned off when I saw that the JL Website recommended running their 600W JLW3 subwoofers at 400W-500W as opposed to their advertised 600W???))
Thanks in advance,
Snapper King
sooo.... I'm getting this feeling that you have the wrong idea about specs of a sub... What does the RMS a sub can handle have to do with the amplifier? You could run 2 Gcons on that power... There isn't a necessity to run the subwoofer's rated power as an exact match... Overhead is nice but not needed either... Under-powering doesn't really exist either...
Reason you don't see SA series in sealed applications frequently is the fact it is geared slightly more towards ported but not 100%..
I just built two sealed enclosures for a guy for his 2 JL w3 12's, both the same to go on opposite sides of his car. Each being 1.3^ft without displacement of the sub, I tested my Sundown sa-12 in there and it did suprisingly well. You will need quite a bit of power to get decent output out of this sub sealed...
I ran 2200 rms and it was clean and loud for a sealed.. But not a "wow" type.
Overall I would say the Sa-12 did great in the sealed. It was pretty acurate Overall
I had my SA-12's in the recommended 1cu sealed before I switched to the recommended 1.75cu ported and the difference is night and day.
I also had a few different amps on them and noticed between 350wrms each and 900wrms each there wasn't a HUGE increase in volume but it was noticable. I would say get a sub that is more suited for a sealed box because you'd be cheating yourself if you didn't port the SA-12's. That's my opinion.
Edited by An-i-no
In this case I would go with 1 15 sealed, either the icon or the fi q (high qts option).
What are some other options for a pair of 12s that will sound really good in a 1.25 ft^3 enclosure with 500-600W RMS? I'd rather not run a pair of underpowered subwoofers. Based on the comments thus far, it seems like i would have to dump a lot more than 1200W RMS to make the SA-12s perform well in a sealed enclosure.
Again, I'd like to stay away from name brand overpriced garbage. Preferably SSA, Sundown, Fi, Skar, etc.
  • 3 weeks later...
I had my SA-12 running in sealed first. It was getting around 750w and sounded good. But, now it's ported and sounds much better. Can't beat it for under 200 bucks.
Just buy 1 SA12 and run it ported. That will take the same space as the 2 12's sealed.
  • 1 month later...
I have my SA 12s in a ported box, with about 820 watts RMS. They sound great, wish I had more power.
In your list I'd vote Gcons.
And to clarify, there is no such thing as underpowering. You surely don't run full tilt all day everyday listening to test tones.
