Posted July 28, 201213 yr I just finished installing my SSA Carbon Fiber Convex Dust Cap and I am really impressed by the way it looks. I have not taking a listen yet, though I'm sure there won't be any audibel difference. Here are a few photos I have taken.Here is a overview of both caps side by sideHere you can that the original cap is "taller". Not exactly sure how this will affect anything.In this picture, it is very hard to see, but I place the new cap over on top of the other, to show that the new cap's "flanged" is just a hair bit longer.In this photo, you can see some bubbles in the crease around the cap before the flange begins.In this photo, pretty hard to see, but really really close up, you can see these "scratches"? I'm not exactly sure where this is from lol. But you have to be really close to see.In this photo, you can see all of its sexyness In this photo, you can see one of the problems I ran into. When removing the original cap, whats left is the glue's residue? I'm not sure what to call it, but it leaves two O-type rings around the former. When trying to lay down the New cap, it would not sit flat or flush. So I was forced to chip away with a small flat head screw driver on the outer ring. The inner ring seems a bit more permanent.Here is the epoxy I just picket up from Lowe's. Seems to work really well. It got real stinky real fast.In this photo, you can see the outter ring chiped away.And here is it installed I got a bit messy This was my first time every doing this, but atleast its clear, so it doesn't look too too bad. Cosmetically though, this looks aMAZEing. Also, I will note that the cap I recieved, did not flush with the cone. It seems that the cone, and the flang are formed at two different angles. Not too too much difference, but enough to not look flush. So I had to use a little bit more glue, and push down as much as I could to try and make sure there is no gaps in between the connection of the cap and the cone.The original cone does seem a bit more "solid" for the lack of term. Like, the original cap is a hard plastic, you could knock on the back of the cap, and it would make a decent "thund". But the new cap, like, I could push it in? If that makes sense. I've never personally handled Carbon Fiber, so I don't know what to expect. Maybe bend but never break kind of thing? lol. It is extremely light though!So overall, I am pleased with this product and would definately purchase more in the future. Thank you very much SSA and Duran for allowing to me purchase another amazing top notch quality item Edited July 28, 201213 yr by Sencheezy
July 29, 201213 yr Due to how the caps are made, those are brush marks from brushing resin on, as you said you must look very close to see them; the same goes for the small air bubbles.Thank you for the review!
July 29, 201213 yr good review CHEEZY glad you kept the review in english and not in your native language
July 29, 201213 yr Author good review CHEEZY glad you kept the review in english and not in your native language hahahahhahahahahah PHUCK you david lmao.But thanks for the kind words sir I went downtown last night,,,, kind of did a little bit of drinking is al i will say. But anywho, the cap held its position. WIN
August 1, 201213 yr Author Get one made. If you need to Duran can have one made.I asked...Duran sent a email over to Aaron.Aaron put in a request to have one sent.
