Today I finally got some time to get some of the wiring done.  I am trying to make this build as clean as possible.  Here is what I was left with when I sold my system lol.
Installed my second 300A fuse and used gorilla tape to hold it down and there is padding underneath of the fuse holder.
Ran my grounds and power wire to two separate terminals that will connect to the second battery in the trunk and then ran those wire from the terminals to distribution blocks for the amps.
Just a close up of the distribution blocks for the power and ground.
Here is a close up of the terminals I was talking about.  These will be going to the second battery.
The wire will be hidden more when I get the box, but the battery will be centered at the very end of the trunk.  Everything has temporary zip ties on them now and they will be cut and tightened when everything is where it needs to be.
Here is the end result, again wires will be cut and hidden more when the box arrives.  That amp is my temporary mids/highs amp until my Sundown amps arrive.  Until then I will be using Hifonics ZXi 80.4 and the Hifonics BRZ 1700.1D.  BTW the power/ground wires will be coming where the speaker wire is currently located, they are just moved out of the way in that pic so I could put the trunk floor back in.
Thanks for looking.  The box should be here Wednesday or Thursday.  It ships tomorrow.
  • Replies 182
  • Views 27k
  • Finally got a chance to do a couple things to my car today.  A little while ago I purchased a YOBO FC16, its a portable Super Nintendo Entertainment System (SNES) that runs on the actual cartridge and
  • Quentin Jarrell
    Quentin Jarrell
    The NES is pimpin. I have an Atari with about 20 games that I'm going to be installing in a demo vehicle. Install is gonna be ole school done up in tweed.
  • Randal Johnson
    Randal Johnson
    Def. wasn't thinking that this would be your logic for using a 20 htz tune ... Cool looking enclosure though ...
Is there only one run coming from the front?
Yea for now. If I ever upgrade to more power I will be adding another run for power and one for the ground. Ground for that battery in the back is to the frame.
can't wait to see this in bear
Everything will be done by then so I am planning on making the trip.  The box ships today and should arrive Wednesday or Thursday.  The only thing I am waiting on now are my Sundown amps.  I will be using my old Hifonics amps until they come in.
Here is the box finished! Ships today. Thanks Dave. If you haven't heard of him or seen his work here you go! All credit goes to DaveTheBoxGuy!
4.5ft3 of net volume, depends on which port is in the box. The port in the box is SPL tuned to 45Hz, the one on the left is daily tuned to 28Hz and the port to the right is tuned to 20Hz for some loowwwwwssss...
563443_10151798728507180_435142209_n_zps
Edited by grayta
alright but the box will make it sound alot different.
What?
That port system looks awesome...is it all PVC plastic?
How much was the box??
The 20hz tuning will be useless unless you use it in a home theatre setup. I loved my 26hz tuned enclosure but it was only a certain amount of songs that actually performed well. That 28hz will give you all the lows you need and can actually hear.
I mainly got the 20hz port to try for hair tricks haha.  I do have quite a bit of songs that are close to that frequency.  My 28Hz port will def be used the most though.  BTW just checked on FED EX and my box will arrive tomorrow around 12n.
I'd be interested in the deminsions on that 20hz port.
Edited by Cablguy184
Def. wasn't thinking that this would be your logic for using a 20 htz tune ...Cool looking enclosure though ...
It's really for sound quality, but maybe it could help with one lol. Thanks the enclosure comes in today. Should be here anytime now. Everything ready for the install. Just waiting for fed ex. Will have pics tonight or tomorrow.
The moment everyone has been waiting for!!!!! Well, mostly me lol.  Anyways on to the pictures!
Setting up and waiting for Fed Ex..
CameraZOOM-20130828111008670_zps5d364e77
CameraZOOM-20130828140551240_zps84c1f12b
Looks a little better in person, but here is the rear deck with Second Skin..
CameraZOOM-20130828140540751_zps648faddf
Some equipment, everything was kind of laid out so when the box arrived, I could just throw everything in. And yes, I know that those amps are not the Sundowns but I am waiting for the amps to come in the mail so for now I will be using some Hifonics amps.
CameraZOOM-20130828145518642_zpsdfc85a82
CameraZOOM-20130828145532979_zps2a6b9627
CameraZOOM-20130828145548405_zpsd64e752d
THE BOX IS HERE!
CameraZOOM-20130828151932699_zps88f5411f
Terminals..
CameraZOOM-20130828152745559_zps8fe7df14
Mounting my EQS to the box.  I never change my equalizer settings but if I need to I can always go back there and change it.  I mainly use it for the pre-amp.
CameraZOOM-20130828153421303_zps54726bb6
Now to seal it off.  Thick cardboard, vinyl, gorilla tape, black fabric, fabric glue and Second Skin.  The cheap way..
CameraZOOM-20130828111826769_zps97e9dd81
Just cut the fabric to match the cardboard and box height and width..
CameraZOOM-20130828112554469_zps47c8bf48
Laying it and glueing part of the fabric to the box and the cutting it out..
CameraZOOM-20130828154205559_zpsc34ff46e
CameraZOOM-20130828154746492_zps1f3147e1
While its drying I drilled the holes out for the amps onto the box.
CameraZOOM-20130828155418819_zps31ddc2c5
Slid the box into the trunk and placed the thick cardboard around it and starting to tape around it with the gorilla tape.  This is from the front side of the box..  I didn't get a picture of this but I glued the rest of the fabric to the cardboard in the front, you will see what I am talking about soon.
CameraZOOM-20130828161156936_zps9ce97f2f
Now to the trunk side..
CameraZOOM-20130828162915353_zpsccd483ce
Now to lay some deadener down to re-inforce the tape.  No point of showing around the whole box because its a tight space so all you will see is deadener and tape lol.  All looks like this picture lol.
CameraZOOM-20130828164028193_zps5bc787d2
That's it for sealing off.  Tomorrow, I am going to open the trunk while playing and see if I am getting any cancellation.  I didn't get a chance to do that today.
The box is screwed into the floor so it won't move, the other L brackets are for the battery.  I vinyl wrapped all the L brackets black to match.
CameraZOOM-20130828164006314_zpsf01be05e
Second battery hooked up!
CameraZOOM-20130828165557420_zps33034f9b
Now to the amps.  Can't wait for my SAZ2500D and SAX100.4 to come in they will look way better in the trunk..  BTW it was a pain in the ass screwing those amps in that tight space lol.  There
CameraZOOM-20130828172743031_zpsf68f41a6
Here it is all finished up..
CameraZOOM-20130828185045664_zps2a052126
I will take more pictures tomorrow, these are kind of dark because it was raining outside while I was doing most of the install so I had the car in the garage.  I will try to get a video of it as well.  Thanks for looking..
Thanks man, it took a lot of time and effort. At first I just wanted to throw it in and hear it, but then I said better do it right the first time. Glueing that fabric was a bitch in the car. It sounds good and gets really low. Can't wait till the subs are more broken in and I get my saz2500
I suck at taking videos but here it is.  On the temporary amp and the gains are set low to break in the subs.  Already can tell I am going to have some flex issues.. lol I can't wait to put my SAZ2500D on these, its already loud but I am ready for louder!! lol
http://youtu.be/GuZvCD1haNk
Edited by grayta
Thanks man. I have all of his new stuff, still need to dl his newest zip 30. Yu coming to the October show?
looking good so far.  keep it up.  I can see why it's so hard to wait for the bigger amp to come in.  should be crazy.
that box is sexy as fuck man.
Looks great!
not sure if you know, but Decaf re-released his stuff...http://www.ram-designs.com/decaf/
I tried downloading this but it doesn't let me play them. how do you get it to play??
did you unzip them? You can use programs such as 7zip or winrar to extract...
