September 20, 201311 yr Author Have you considered zcons? What is it about the xcon that has you interested in them?well i really dont want to put out more money then what the truck cost me im looking about $2200 i bought the truck used for 4k i mean if i wanted to spend that much for 4 subs i would but two smd 18s
September 20, 201311 yr Have you considered zcons? What is it about the xcon that has you interested in them?well i really dont want to put out more money then what the truck cost me im looking about $2200 i bought the truck used for 4k i mean if i wanted to spend that much for 4 subs i would but two smd 18sNo you wouldn't, they are discontinued
September 20, 201311 yr Author Got to look around just in the matter of your last post i found 4 of them
September 20, 201311 yr Author But is anybody going to answer my last post about the box and the size
September 20, 201311 yr Do these subs like a open box like 48wide 18 tall 28deepThat's 14 cubic feet total. In that space I would do two 18s. That is not the same dimensions from your first post
September 20, 201311 yr Author Do these subs like a open box like 48wide 18 tall 28deepThat's 14 cubic feet total. In that space I would do two 18s. That is not the same dimensions from your first postWell you said properly designed and built enclosure i dont want to big 4ftx4ftx2ft is kinda big for that sub i would think Edited September 20, 201311 yr by bass4life
September 20, 201311 yr Author Do these subs like a open box like 48wide 18 tall 28deepThat's 14 cubic feet total. In that space I would do two 18s. That is not the same dimensions from your first postWell you said properly designed and built enclosure i dont want to big 4ftx4ftx2ft is kinda big for that sub i would thinki think thats somthing like 25 cubs
September 20, 201311 yr For which subs ? your posts are all over the place.How many subs?What size?Which subs?48x48x24 is 32 cubic feet, which is huge
September 20, 201311 yr Need to figure out what subs your going to get then have the enclosure designed for them
September 20, 201311 yr Author im stuck i like the xcon 15 and the gcon 15 and im wanting 4 of them Also i build my own box's
September 20, 201311 yr Author I'm asking what amplifier you have?I dont have any till i get the subs then ill buy the amps to match i will buy 2 amps to power 4 subs
September 20, 201311 yr Decide on how much power you want to run. There's a huge difference between the two woofers power handling. 3000w for 4 gcons or 7000w for 4 xconsMore power is going to cost you more in wire, batteries, alternators, etcetera
September 20, 201311 yr Author For 4 fifteens, you will want 16-20 cubic feet before portok so a 18x48x48
September 20, 201311 yr Should price out some amps and batteries before deciding. Your going to see the subs probably won't be your biggest expense.
September 20, 201311 yr For 4 fifteens, you will want 16-20 cubic feet before portok so a 18x48x48Yeah that's 24 cubic feet
September 20, 201311 yr Author i got 3 batts Kinetik KHC1400 old but they work and the big 3 already Edited September 20, 201311 yr by bass4life
September 20, 201311 yr Should price out some amps and batteries before deciding. Your going to see the subs probably won't be your biggest expense.This is a great post, you need a total budget. Woofers are just a small chunk of the budget.
