Have you considered zcons? What is it about the xcon that has you interested in them?
well i really dont want to put out more money then what the truck cost me im looking about $2200 i bought the truck used for 4k i mean if i wanted to spend that much for 4 subs i would but two smd 18s
  • Replies 73
  • Views 8.1k
  • Do you have everything else you will need? Batteries, amps, an alternator etc? How much power do you want to run and what are your goals?
No you wouldn't, they are discontinued
Got to look around just in the matter of your last post i found 4 of them
But is anybody going to answer my last post about the box and the size
Do these subs like  a open box like 48wide 18 tall 28deep
That's 14 cubic feet total. In that space I would do two 18s. That is not the same dimensions from your first post
Well you said properly designed and built enclosure i dont want to big 4ftx4ftx2ft is kinda big for that sub i would think
Edited by bass4life
i think thats somthing like  25 cubs
Need to figure out what subs your going to get then have the enclosure designed for them
im stuck i like the xcon 15 and the gcon 15  and im wanting 4 of them
Also i build my own box's
for 1088 i get 4 gcon and xcon are almost 3k
price for 4
Edited by bass4life
I'm asking what amplifier you have?
I dont have any till i get the subs then ill buy the amps to match i will buy 2 amps to power 4 subs
Decide on how much power you want to run. There's a huge difference between the two woofers power handling. 3000w for 4 gcons or 7000w for 4 xcons
More power is going to cost you more in wire, batteries, alternators, etcetera
For 4 fifteens, you will want 16-20 cubic feet before port
ok so a 18x48x48
Should price out some amps and batteries before deciding. Your going to see the subs probably won't be your biggest expense.
lets get off this board and chat
i got 3 batts Kinetik KHC1400 old but they work and the big 3 already
Edited by bass4life
This is a great post, you need a total budget. Woofers are just a small chunk of the budget.
