Posted November 4, 201313 yr As the title states... Im looking for the recommended box sizes for the subs (both sealed and ported). The place where they should be listed on Sundown's website are all blank. Tried searching as well... but no luck. I at least found the displacement on the 10" is .25 Thanks in advance for your help fellaz!
November 14, 201312 yr 3-4.5 cubes ported I know that. These subs should work better in ported than sealed if irrc.I would go as much as 5 if ur on lower power.
November 14, 201312 yr 3-4.5 cubes ported I know that. These subs should work better in ported than sealed if irrc.I would go as much as 5 if ur on lower power. If he is looking at a 10 then thats way too much. You must be talking about a 15.
November 14, 201312 yr 3-4.5 cubes ported I know that. These subs should work better in ported than sealed if irrc.I would go as much as 5 if ur on lower power. If he is looking at a 10 then thats way too much. You must be talking about a 15.You're right lee. Idk why I was thinking he was saying a 15.1.25-2 cubes for 10". I got this info from sundown when I called a while back.
