Posted May 23, 201412 yr I got a F I Q motor with BP option from around 08' era. Would a zcon or a xcon recone fit in it..????
May 23, 201412 yr Author The coil length on the Q is just shy of 2.5". I know either zcon or xcon has similar length..
June 21, 201412 yr The newer Fi Q recones will work. You will be happier with just doing that. Just include in the message box that its for a pre-09 motor.
June 25, 201411 yr Author The newer Fi Q recones will work. You will be happier with just doing that. Just include in the message box that its for a pre-09 motor.What are the differences between newer and older soft parts??
June 25, 201411 yr You should buy this one so you if you wanted another it's easy to match and seem me yours so I can have a match lolhttp://www.****/forum/12-subwoofers/170697-fi-q-12-ugly-little-guy-2.html
June 25, 201411 yr Author You should buy this one so you if you wanted another it's easy to match and seem me yours so I can have a match lolhttp://www.****/forum/12-subwoofers/170697-fi-q-12-ugly-little-guy-2.htmlMy motor doesn't look anything like that one....
