Posted November 17, 201411 yr Hello all! This will be really really slow going since this is a high school build lol. Anyways, I started out 2 years ago with a 92 pontiac sunbird and put a little pioneer 12 in it and its been a steady road ever since. Here i am now with a newer vehicle and bigger plans. Vehicle: 03 Jeep Grand Cherokee Current Gear:Kenwood KDC-X3974 gauge knu ccaAlpine MRV-500SSA Xcon 18 Future: Crescendo Symphony 1500 (hopefully soon)1/0 Welding Cable....maybe two xcons c-pillar wall.... The jeep Kenwood Most recently removed setup Box And its In!!!! Edited November 17, 201411 yr by afearlesshunter
November 17, 201411 yr Looks good! How's it sound. I sure wish I had a clue about car audio back in hikes school.
November 18, 201411 yr Author Looks good! How's it sound. I sure wish I had a clue about car audio back in hikes school.Thanks! I'm not sure how it exactly sounds since its below 15 degrees here.. I have been playing it but its so cold the sound is a little different than actual warmth lol. On 250 watts or so (Gain set at -3db so maybe a little less on music) it isn't as loud the two 12's but the lows are ridiculous. Can't wait to get a real amp on it.
December 5, 201411 yr Author Crescendo Symphony s1500 arrived! On 4 gauge for now 4 ohms fused at 80 amps Subsonic set at 10z because anything above that i start losing a ton at 27hz... help lol
December 5, 201411 yr Enclosure is tuned to 30hz.Are you sure? Did you design the enclosure or did somebody else do it?Need dimensions and specs as to how you determined that.Also sounds like you don't have enough electrical to run it. Do you have extra batteries?What is the voltage at the amp? Edited December 5, 201411 yr by pmureika
December 6, 201411 yr Author Enclosure is tuned to 30hz.Are you sure? Did you design the enclosure or did somebody else do it?Need dimensions and specs as to how you determined that.Also sounds like you don't have enough electrical to run it. Do you have extra batteries?What is the voltage at the amp? SSA Designed the box, they say its tuned to 30hz so thats the info I'm rollin with.136 amp alternator with a group 65 diehard gold for now. Power will and big 3 will be 1/0 when it comes in the mail. I do plan on getting a 270-320 amp alternator in the next few months. For now gain will be set accordingly for the electrical i do have and I will be getting a new volt meter to monitor hopefully at the battery and the amp itself. Amp sees between 13.8-14.4 depending on temperature. No voltage drop so far, we'll see what happens with more power. Edited December 6, 201411 yr by afearlesshunter
December 6, 201411 yr Something sounds a little off to me that the subsonic is affecting the signal as soon as you start to turn it up. Even so, if you built the enclosure exactly as the designated design calls for then it should be right. The thing to do is start to play a tone at about 25 to 27hz and turn it up enough to get the sub moving as good as you safely can. Then turn the subsonic up until you see about half the movement you did before you adjusted the subsonic. That will have the subsonic set where it should be. I just noticed you're a fellow Hoosier. Where you at in this state?
December 6, 201411 yr Author Something sounds a little off to me that the subsonic is affecting the signal as soon as you start to turn it up. Even so, if you built the enclosure exactly as the designated design calls for then it should be right. The thing to do is start to play a tone at about 25 to 27hz and turn it up enough to get the sub moving as good as you safely can. Then turn the subsonic up until you see about half the movement you did before you adjusted the subsonic. That will have the subsonic set where it should be. I just noticed you're a fellow Hoosier. Where you at in this state?Thanks, ill try that this weekend since it will be in the garage all weekend. Got bags for the rear and some other goodies Im in Greenfield IN. white trash central. lol
December 6, 201411 yr Awesome, nothing like goodies for the ride! Greenfield, neato, lol. I've only ever driven through on the interstate, never been to the area for any length of time so I don't know anything about it. There's nothing but fields and coal mines around here, but if you ever have a reason to come down to Knox County (or nearby) look me up!
December 11, 201411 yr Author Was about to order fuse blocks and terminals but shipping is as much as the order... holy f... Guess i need to wait to buy other stuff and raise my total lol
January 1, 201511 yr Author Welding cable is all in. Big 3 is done. Just waiting on speaker wire to show up friday to drop to 1 ohm
January 3, 201511 yr Author Dropped to 1 ohm. Slams like none other. Not sure what to do about the sun roof and headliner flopping everywhere ...
