Posted December 23, 201410 yr Hey guys, This is a project I've been working on for a while... it's origins date back to 2009 with my unfinished 4" coil Neo design (some may remember it) : http://www.caraudioclassifieds.org/forum/sundown-audio/19945-proto-neo-4-motor.html I put the whole thing on hold to concentrate more on things that would really grow the company & our dealer base. That being said... fast forward 5 years now and I have the opportunity and ability to work on this again. As far back as 2009 I knew I wanted to go after my Neo SPL design with a 4" coil -- so I did that again. This time I went for a good bit more Neo and a different / unique design : So this is my first prototype / first fully completed Neo prototype. This may not be the 100% final version but I think it's close. I should have it in my hands early on in January for testing. Few quick details that I am releasing now... 1) 4" voice coil 2) 16 slugs of N42H Neo (N48H was a large cost increase with almost no increase in flux) 3) Will be sold in 12s, 15s, and 18s 4) Pricing is TBA as I go over all the final costs of the motor... certainly not cheap; the motor itself costs about as much as 7 pcs Z v.4 motors based on my early estimates. 5) It is mated to a 10" frame in the photo for size reference; but I don't currently have plans to make them as 10s 6) Motor weight is ~70 lbs... overall external size is almost identical to a Z v.3 motor. That is about it for now... except for a quick photo of my Neo chunks : These look a little rough as they were cut into shape; when we end up doing production we'll tool the exact size/shape we end up with so they'll look perfect.
December 30, 201410 yr Author Okay so I've done the math -- so far on a 15" model as that is what we'll be building first for our Terra. MAP from an authorized dealer will be ~$2199 for a "standard" unit (any of our compatible "standard" parts can be used at this price) -- we are still pricing out composite cones, though.
January 1, 201510 yr One of these with a chrome basket and carbon fiber cap would be niceOr would a different basket not work?
January 3, 201510 yr Okay so I've done the math -- so far on a 15" model as that is what we'll be building first for our Terra.MAP from an authorized dealer will be ~$2199 for a "standard" unit (any of our compatible "standard" parts can be used at this price) -- we are still pricing out composite cones, though.Purely a SPL woofer? or will the soft parts make enough of a difference to make a more flat response with emphasis on low end? just curious.Either way, good to see a big neo motor that wont be completely shielded of all the specs like the Warden and Z.
January 5, 201510 yr It's meant for SPL. Same concept with DD Z or the BTL N3. It will still play music, but will not be considered as an music sub.
January 12, 201510 yr this will be a killer sub. keep it up, i got 2 sundown e series 12s to try out incase i want to switch from a die hard fi guy to a sundown guy and i am overly inpressed with your work. the 12s kill it. i will forever be a fan
