Posted February 7, 201511 yr Well, here are the components to the dream build. Just finished the last one up last night. (2) RE XXX 12" OEM coil 1 stiff, 1 soft spiders Original full face dust caps Amps MMATS HD4000.1 MMATS SQ4100 Speakers: (2) Sets of Infinity Kappa 6.5 components Electrical: Singer 250A 3 runs 2/0 Duralast platinum(front) (still needing rear batteries) Vehicle: '04 Pontiac Grand prix Enclosure talk: I have experience with this driver in different sizes, and had always had good results with the enclosures for them. Haven't done a multiple woofer set-up for almost a decade, but this is what I was thinking.. 4.5 cu. ft. L port, double baffle, window bracing, 45s Going to start with subs back port back, and if I want to I will flip the box around and seal a trunk wall. Anyone with experience with these drivers want to chime in? I'm thinking with the power I had I would want to keep air space around 2 cubes each. Would also contemplate center port, but would change up bracing a bit. Gotta wait for the weather to break to get this built! Now for the photo shoot...
February 8, 201511 yr I just got a 04 gtp. I'll be reckoning my '08 Fi Q and moving my amps over from my blazer.
February 8, 201511 yr Author You can fit a 15" but its a snug fit Edited February 8, 201511 yr by cloud77
February 20, 201511 yr Author Nice. This setup is gonna be LOUD! I hope so. but I'm not really worried about numbers. Just some clean old fashioned XXX sound
February 20, 201511 yr Author I might be down at a show in Columbus/Mansfield this season, so maybe you can =]
February 20, 201511 yr I might be down at a show in Columbus/Mansfield this season, so maybe you can =]I should be going to some of them once my van is playing
February 20, 201511 yr Author I might be down at a show in Columbus/Mansfield this season, so maybe you can =] I should be going to some of them once my van is playing right on. you sticking with zcons?
February 20, 201511 yr I might be down at a show in Columbus/Mansfield this season, so maybe you can =]I should be going to some of them once my van is playingright on. you sticking with zcons?Yea got 4 right now
March 29, 201510 yr Author So I finally got some footage...Equipment is as listed. MMATS HD4000.05MMATS SQ4100(2) RE XXX 12"s 04-05 XBL^2Juice box black cherryKNU 1/0 OFCSinger 250AInfinity components
April 3, 201510 yr Author definitely would want to run them inverted though to smell any issues and to show the drivers off
