Posted October 31, 20178 yr Hello all, I have been away from the forums for some time since graduating college and started working again. Now that I have some money to finally move away from these seemingly low powered setups (6 systems since 2012), I am looking for help with my wall build. I am going to be building the base to the wall in my 2016 Ford Focus sedan in a week or two, and there is a lot of room to work with (over 30 cubes). I will be running 2 18" ZCONs on (undecided) either a 5.5k or 6.5k amp with supporting electrical (batt bank, lots of OFC wire, and HO alt). This is my daily, and I just want a ground pounder with no care to what numbers it'll put up in the lanes. I would like to demo a lot. I'm thinking 8 cubes per sub (16 cubes net) tuned to 32 Hz is a good place to start (recommended by SSA). I'm thinking either a center slot port, or a top port. ** I listen to ALL kinds of music, Decaf/DJSNT, rap, hip hop, metal, rock, 80s/90s pop, jazz, country, movie scores, blues, dubstep/electronic, classic rock, oldies, etc, etc..** Now... my questions are: How much port area do y'all recommend? Is 8 cubes of net volume per sub a good amount? Should I be alright running an underrated 5500 watt amp, or go with the 6500? What port orientation shall I go with? If I think of more questions, I will be sure to post them. P.S. Sorry if I am asking some questions that are common knowledge among these builds, but this is my first "loud" and "high powered" setup. My two loudest systems thus far have been a single Obsidian Audio 15 on about 900 watts, and 2 Sundown Ev3-12's on 1300 watts. Thank you for your time and patients everyone! Cheers.
October 31, 20177 yr Nice choice on subs. Check out my latest build log. Just got done with my wall with 2 zcons
October 31, 20177 yr They forsure can handle ALOT of power but dont need it. they will do fine on anything you give them. But I would get as much power as you can afford. . 8 cubes each is a good place to start and I would go with at least 110-120 sq in of port each. Im right around 235 or so for both of mine right now.
November 1, 20177 yr Author 13 hours ago, frogcase2002 said: They forsure can handle ALOT of power but dont need it. they will do fine on anything you give them. But I would get as much power as you can afford. . 8 cubes each is a good place to start and I would go with at least 110-120 sq in of port each. Im right around 235 or so for both of mine right now. Thanks for pointing out your build log. I like that you actually kept up with the posts and gave a great overview of the major steps. Money isn't a huge concern, I mean sure I'd like to pinch pennies, but I have been doing that since 2011 (I'm only 23)... So I am basing my budget off of what amps (and all their competitors) cost. I can get a 6500 for $1400 (Audio Legion), but am starting to look at a Brazilian board like your Taramps. May consider SounDigital. Probably smarter to have a larger amp and slowly build up electrical rather than regretting buying a 5.5k. I digress... How do you like the 10k Taramps thus far? Also, do you recommend the 33Hz tuning, or should I go for 34-35? According to SSA, any of those number are within the recommended tuning range for the newly revised ZCONs. Thanks for your help!
November 1, 20177 yr Author Hmmm, on the fence now between a Taramps 8k and Soundigital 8k. Taramps is far less expensive, but the SD is still a good value. How is the 10k treating you? Edited November 1, 20177 yr by mikebingham34 Changed question to other forum member
November 1, 20177 yr So far I like the taramps. Forsure for the price. But I only have the stock alt on right now so havnt seen what it can really do yet . I have done a few setups for people using taramps and there forsure decent for the money. . I think 33 hz would be about perfect . Wouldnt go to high if you like the lows
November 8, 20177 yr I used to see a lot of brazilian amps with problems, they were catching fire, or breaking fast. Nowadays it seems different : I can see alot of Taramps, SD, (no more Stetsom though)... Fi sells Banda on their own site ! What is going on ? Why are they suddenly so good ? They're cheap, powerful, and now reliable ? BTW : nice choice on subs. You'll love them. Edited November 8, 20177 yr by Notorious97200
