Posted November 19, 20178 yr Hello, I was looking at the recommended box size for the Flatlyne 15 and it is at 3 CUFT. What is the recommended port area? Thanks.
November 20, 20178 yr Author My main reason for posting my question is when I input the T/S parameters for the Flatlyne in a box modeling program, the results are all wacky. Usually when I start a new build, I try to model my box to what I feel like will suit my goals. I am trying to model the smallest port I can get away with a 15 so I can keep my box volume down. The spreadsheet, although useful, does not really help me because it just takes into account the box volume and input power, not the subwoofer. I appreciate the help though.
November 21, 20178 yr Author Tricia Wright from Incriminator Audio got me all the info. Pulled the trigger on the 15, thanks!
November 22, 20178 yr Author I apologize, I should have shared already. Here are both emails I got from IA: " The recommended ported box specs are 2.5 – 3.5 cubes with 12 – 16 inches of port per cube. Let me know if you need anything else." "The recommended ported box specs are 2.5 - 3.5 cubes with 12 - 16 inches of port per cube. Yes, you can use a 6" aero port if you keep the box around 3 cubes. "
November 26, 20178 yr Author I have my box modeled up, it will end up being 3.33 CUFT @ 30 Hz. My amp is a DLS Audio CC-500, HPF is set at 30Hz.
December 5, 20178 yr Author Thanks. It came out nice. It is pretty heavy, maybe 50 pounds. I can't wait for the Flaylyne to get here.
December 5, 20178 yr Nice box. I haven't heard of the duratex before your post. How did you apply it? It looks very nice and I may use it in the future. Hope to see more of this build soon.
December 5, 20178 yr Looks great. Where did you get it from ? Is the texture on the smaller end? I used a deck liner from Home Depot once. It had a nice look from far but up close it was real jagged. And it left dust every time I’d move it a bunch.
December 5, 20178 yr On December 4, 2017 at 1:12 AM, ClevelandFreeman said: Rounded the edges, I'll duratex maybe tomorrow..... Painless & easy on the nose! Find it here: https://www.acrytech.com/product-category/speaker-cabinet-coatings/ they even do some color matching.
December 16, 20177 yr Author Sub is here! Build quality is excellent, can't find nothing wrong with it. Packaging was great. Edited December 16, 20177 yr by ClevelandFreeman
