Looks good so far, nice drill as I just bought one myself.
  • Replies 54
  • Views 8.2k
2 hours ago, frogcase2002 said:
I wouldnt do it if you cant seal it off all the way
It’ll be sealed. Just saying thought there could be some cancellation due to the sub and port being larger than I could cut the hole.
Dont think I would do Ported If I couldnt cut It out the Same size as the enclosure
Test fitting
Oh ok good to know. Hearing that from someone more experienced.
What if I was to make it like yours. How the sub is facing the plexiglass glass. And I make it a little tunnel into the cut out? I guess that’s like a 6th order idk. Would that little tunnel make a drastic difference ?
And whats eats your projection on the out out of the box? What kind of ratio did you design it around
Going to use  some roll on bed liner to protect the enclosure from weather
It would be different if it was my build . Had to work with the room dude wanted to use. Ended up with about 7 cubes net in the ported section which left about 3.5 in the sealed. Wasnt much I could do with the space available and size of the subs. . If it was mine I would have made it as big as possible so I was able to go in and experiment with different sizes of each section. Change port size. Tuning
Paintin a little
Should look nice with plexi and led's . And the subs in there
Man them evils look good
Looking sweet
Dope ass hell man, the plexiglass and lights really set it off. :droolcup:
Would have it playin if the dam accordian boot would have gotten here. Ordered it almost a week ago. Coming from the same state .. says it will be here tomorrow though
How big did you go in the sealed section
Little over 3.5
Oh and that’s for both subs? Interesting.
