nauc 0 Posted March 19, 2007 about how many dbs can you get going from 1 sub with say 500 watts to 2 subs with 1000 wattsthanks 0 Share this post Link to post Share on other sites
Acidburn 10 Posted March 19, 2007 anywhere from 0 to 155 0 Share this post Link to post Share on other sites
tejcurrent 13 Posted March 19, 2007 Honestly there is no real way to answer that question. It depends on the setup, what subs, and so many variables there's no way to begin. It is said in the same setup you gain 3dbs by doubling power, and 3 dbs by doubling cone area. If you are also putting in a bigger box, tuned different, with 2 different subs, etc, etc, there's no telling. I had 1 sub getting 2k watts, put in a 2nd sub and another 2kwatts, and gained between 1-3dbs depending on the frequency.This just goes to show, there is no way to put a figure on it. Will it help if I just say it should be louder? 0 Share this post Link to post Share on other sites
Silverbane 0 Posted March 19, 2007 Honestly there is no real way to answer that question. It depends on the setup, what subs, and so many variables there's no way to begin. It is said in the same setup you gain 3dbs by doubling power, and 3 dbs by doubling cone area. If you are also putting in a bigger box, tuned different, with 2 different subs, etc, etc, there's no telling. I had 1 sub getting 2k watts, put in a 2nd sub and another 2kwatts, and gained between 1-3dbs depending on the frequency.This just goes to show, there is no way to put a figure on it. Will it help if I just say it should be louder? Obviously Noticeably louder... 0 Share this post Link to post Share on other sites
nauc 0 Posted March 19, 2007 yah, im talking about using the same subs, both in the same size sealed box so say, 1 12" off 500 watts sealed in 1 cube and then stepping up to 2 12"s off 1000 watts and a 2 cu ft box (1 cube per sub)i know every car/setup wont be the same but just wondering theoretically speaking... 0 Share this post Link to post Share on other sites
dopey 0 Posted March 20, 2007 135-140ish.If youre lookin for spl...sealed isn't the way to acheive it. 0 Share this post Link to post Share on other sites
