Posted August 23, 201015 yr like the title says...is a q12 fully loaded worth 100$ more then a fully loaded ssd 12
August 23, 201015 yr Author No its only worth 75 dollars more.close enough...why do u need more info? in general is it worth the difference. ill build around the sub
August 23, 201015 yr Becuase knowing your goals or intentions on the setup will tell you if its worth the 75 extra bucks to shell out for a Q or not.
August 23, 201015 yr in general is it worth the differenceknowing your goals or intentions on the setup will tell you if its worth the 75 extra bucks to shell out for a Q or not.^this.Both sound good, one is able to handle more power and is Fi's SQ driver. More power generally means more output, though not always, meaning if you can give a Q with BP option twice the power you should expect it to be a bit louder. It should also sound a bit better, but install is going to determine everything. This is why people ask for the details of your setup, answering a few questions is necessary for people to give you a good answer.
August 23, 201015 yr Considering this is third time you asked and you still havent got a answer, just do things the way we are asking so we can help you. They are two different drivers that are suited for different goals and needs so that is why were are asking what are your intentions.
August 23, 201015 yr Considering this is third time you asked and you still havent got a answer, just do things the way we are asking so we can help you. They are two different drivers that are suited for different goals and needs so that is why were are asking what are your intentions.If you can answer these questions, you will then receive helpful answers to your questions, that will in turn help you make the proper choice.
August 23, 201015 yr You don't buy subs here first and then build around them...You pick up everything else first and then build around the sub accordingly...It's the difference in purchasing something that is just 'off the shelf' and gets a UPS label thrown on it, and something that is a truly totally custom built to order sub.
August 23, 201015 yr You don't buy subs here first and then build around them...You pick up everything else first and then build around the sub accordingly...It's the difference in purchasing something that is just 'off the shelf' and gets a UPS label thrown on it, and something that is a truly totally custom built to order sub.This is probably the truest thing when it cones to car audio in general. It's like picking an engine before you even know what car you're going to get.
