Posted November 4, 201213 yr As the title says...I have 14.25 cubes available. I want to run 2 zcon 18's. I don't know anything at all whatsoever about designing a box.With that said, after subtracting driver displacement, port displacement, and bracing, will I have enough room?If not I have a Zcon 18" Dual 2 for sale lawl
November 4, 201213 yr I fit 2 zcons in around that space, a little less.I think I had mine in around 6 cubes each and they did very very well.
November 5, 201213 yr Author Sure they'll fit. The packaging they come in is only around 2.5 ft^3So I can just cut a hole in the crate and run them that way?
November 5, 201213 yr Sure they'll fit. The packaging they come in is only around 2.5 ft^3So I can just cut a hole in the crate and run them that way?Yea you don't even need a port. The cardboard acts as a passive radiator
November 5, 201213 yr Depending on how much you lose in bracing and the port, it could work. I had mine in about 3 net each.
November 5, 201213 yr Author Depending on how much you lose in bracing and the port, it could work. I had mine in about 3 net each.The 18's or the 15's?
November 7, 201212 yr Depending on how much you lose in bracing and the port, it could work. I had mine in about 3 net each.The 18's or the 15's?both. 2 18 and 4 15s. Same wall.
November 7, 201212 yr 6cubes net is lowest I would go anything below that I would hate my ears.what does 5 cubes or 6 cubes have to do with your ears?
November 8, 201212 yr 6cubes net is lowest I would go anything below that I would hate my ears.what does 5 cubes or 6 cubes have to do with your ears?sounds like poop.
November 8, 201212 yr So it sounds like poop if its in 5 cubes but not 6? Maybe learn how to tune an enclosure. Mine are in a small box and digs low as fuck.
