Posted July 19, 201312 yr Hooked the RedStar Neo up to 110volts on each coil and let her go.... Good times!!http://youtu.be/XglfJ10tryA
July 19, 201312 yr Author Yeah it took it for a decent amount of time, especially for having 110 to each coil
July 19, 201312 yr Just curious why you did it to a sub that had two good coils? Just wanted a recone?
July 19, 201312 yr Author Actually the motor was being sold as just that, just a motor. So Figured I'd have a little fun with it before it was shipped off. Plus easier to ship with just the motor and not basket anyways
July 19, 201312 yr Author Theres another video on my youtube channel of me doing some testing with it when I first got it... Ended up getting a 148 sealed on music with a single 12
July 19, 201312 yr Author Not sure what the subs are getting built into now, with the right parts they will be undestructable though. That 4" coil that was in it took some abuse
July 19, 201312 yr 12100W on each coil fyiNot even close. Even if the outlet was on a 20 amps breaker it's only getting 2,200 watts. 110volts at ~60 hertz times 20amps = 2400 watts. Anymore and the breaker would have thrown.
July 19, 201312 yr Author When I had the coils wired as one, it continuously popped the 30 amp breaker. I just stood by the box and kept resetting it for about 5 minutes. After that I said F it and wired up each coil to a seperate 30amp breaker
July 19, 201312 yr Post a link to the video. Was this in a shop or warehouse? I can view it on mobile.
July 19, 201312 yr Post a link to the video. Was this in a shop or warehouse? I can view it on mobile. Edited July 19, 201312 yr by stefanhinote
July 19, 201312 yr Author You can check out RedStar on Facebookhttps://www.facebook.com/groups/192488357542032/
