Posted September 15, 20169 yr Figured id start the build log . Dont have any pictures yet though. If anyone remembers this is the car I had the trunk wall with 2 12" zcons a while ago . Then reconed the zcons to 18s and walled them in a van. Well the van rear end boke in half on the way to slamoligy this year so now going to wall the sable . Will be 2 18" zcons Taramps 10k (bought one to try out. Never tried a taramps befor) Ssa evil mids . Not sure on the highs yet Ppi 900.4 Singer alt 4 130something ah dekas and an xs for under the hood Lots of welding cable I will start posting pictures once I start on the wall
September 15, 20168 yr 2 hours ago, frogcase2002 said: Figured id start the build log . Dont have any pictures yet though. If anyone remembers this is the car I had the trunk wall with 2 12" zcons a while ago . Then reconed the zcons to 18s and walled them in a van. Well the van rear end boke in half on the way to slamoligy this year so now going to wall the sable . Will be 2 18" zcons Taramps 10k (bought one to try out. Never tried a taramps befor) Ssa evil mids . Not sure on the highs yet Ppi 900.4 Singer alt 4 130something ah dekas and an xs for under the hood Lots of welding cable I will start posting pictures once I start on the wall Lol don't be taking pictures with that damn 1996 flip phone. If you need any help holler at me.
September 15, 20168 yr Author LOL nothins wrong with my phone! I wont be using it for the pictures though lol. Wouldnt be able to even see anything. . . . You can probably come by the shop when were working on it after your off work sometimes . . . The place is right by the end of bethany off cincinnati dayton rd
September 15, 20168 yr 9 minutes ago, frogcase2002 said: LOL nothins wrong with my phone! I wont be using it for the pictures though lol. Wouldnt be able to even see anything. . . . You can probably come by the shop when were working on it after your off work sometimes . . . The place is right by the end of bethany off cincinnati dayton rd Sounds good. Lmk when you start. I'm pretty sure a potato would take a better pic than your phone. Lololol
September 15, 20168 yr Author I bought a cherokee to do a new big buid in after the van messed up but just decided to use the car I had cause it already has rcas and some 1/0 ran and door panles are already fiberglassed real good . . Pretty much just need to order the new alt . Maybe some more power and ground runs and the evil mids. Then get mass wood and fiberglass for the wall
September 16, 20168 yr Author Next to the mids in the doors . Around were the stock location for the mids are but the door are fiberglassed. Little lower then where my knee is . . . And will be uning my clairion 702 to do 2 way active for the front. Amp is the ppi 900.4
September 16, 20168 yr Author Can probably put them in other places though . Plan was the doors though
September 16, 20168 yr Popular Post This: versus Reason being there are nearly no small format tweeters that can dig and play nice off axis (hint Aaron ). Opening up the search to large format if they fit is worthwhile. Your doors are HUGELY off axis so you need something with a nice response in that regard. In small format, the standard was the LPG 25nfa (now replaced) but it didn't do jack below 4kHz. The Evil mids will play nice and high, but having a tweeter that can play lower really maximizes what you can do setup wise with the processing to optimize the sound.
September 16, 20168 yr Author Well my doors are fiberglassed to fit 2 6.5s in each door so I was thinking I can just do 1 evil mid in each door and can make like a baffle for whatever tweeter I get for the other 6.5 hole
September 16, 20168 yr Author Thats what I would like to do forreal . It would probably help with hearing the words over the zcons
September 16, 20168 yr Author But really in the van I could hear the front stage pretty decent when playing the subs loud and I had 1 10 dollar mid and 1 3 dollar tweeter from parts express in each door . And I was doin a 153 in there. So one evil in each door probably wouldnt be to bad
September 16, 20168 yr Im just a fan of tweeters being in a higher location. Kinda seems to raise the stage height. Why not horns or a line array of full ranges/tweeters in A-Pillars?
September 16, 20168 yr Author Would be cool to have horns but there kinda out of my price range. . I could fiberglass something in the a pillars. Just need to figure out what
September 16, 20168 yr 1 hour ago, jcarter1885 said: Im just a fan of tweeters being in a higher location. Kinda seems to raise the stage height. I totally agree : I like my tweeters high, in the A pillars or on the dash !
September 17, 20168 yr 2 mids is a waste unless you run in 2.5 way but you will need more processing for that
