January 26, 20187 yr Author Thanks guys! I ordered big 3 is on the way... I'm itching get a another 10 inch and get a high output enclosure sub box.. Will see if my budget can afford..lol.
January 26, 20187 yr Author On 1/16/2018 at 1:39 PM, Notorious97200 said: 4 Ga input to 4 Ga ? why ? Keep posting pics. I like clean look connection to amp input..
January 30, 20187 yr Author Just got big 3 upgrade 4 g from gp audio 4 ft power and ground cable.. I just realized my alternator passenger side is lower of engine..it looks going to be pain in the ass from going under to work on.. I thought is top side engine.. But I'm wrong..lol.. My only problem is the cable is little short to reach battery post.. But i didn't add fuse with it.. So maybe it can reach to battery post.. Will see.. and definitely will take pictures..
February 6, 20187 yr Author Ok i have questions.. Today got my fuse bock plastic bottom cover that melts.. I did check grounds are good and had bare metal connection are good.. My amp is power acoustik 3000.. I only use 1,800 watts for one 10 inch sub.. And 4 gauge power cable.. I'm try to think.. Maybe i need 0 gauge?
February 9, 20187 yr Author On 2/6/2018 at 4:13 PM, frogcase2002 said: Are the connections in the fuse black really tight I did actually swap out new mmats pure cooper power wire..that thing is heavy feeling.. I paid alot for this one than cheap.. Man it pull more power juice and hits harder now.. I'm glad to fix it.. Oh and my amp just warm while play longer....
February 9, 20187 yr Author I'm try to figure out how to stop dimming head lights.. I know there is big 3 upgrade but it's pain in the butt is take passenger side wheel off and wheel well cover off to work on.. I just wish were simple like old cars.. Lol.. And or upgrade agm battery. Only singer sells alternator.. Other brands don't because of pulling is small on factory.. I'm try stay away from volt cap.. Some said is bad for alternator
February 9, 20187 yr Installing a second battery in the back of the vehicle is another option, that will stop or reduce your headlights from dimming. Even without installing the Big-3.
February 9, 20187 yr Author 1 hour ago, j-roadtatts said: Installing a second battery in the back of the vehicle is another option, that will stop or reduce your headlights from dimming. Even without installing the Big-3. What kind battery should i get? My amp is 2 ohms of 1,800 watts and plan on another 10 inch sub. Also plan on get amp for mids and highs soon. Oh yea i have small space in back. Hopefully get small battery right by spear tire.
February 10, 20187 yr An agm battery would work great. I use x2 power for mines. But yellow top works as well. Not sure what’s avaloable to you
February 10, 20187 yr 22 hours ago, Boom sonic said: What kind battery should i get? My amp is 2 ohms of 1,800 watts and plan on another 10 inch sub. Also plan on get amp for mids and highs soon. Oh yea i have small space in back. Hopefully get small battery right by spear tire. The battery MUST be a sealed type like an AGM. Otherwise will gas into the car. I did the same thing because I couldn't reach the alternator. I bought the biggest battery they had at the parts store and mounted it next to my box. Other route is weld in a battery box next to the spare tire. I am running 2000 Watts to my subs, and two more 600 watt amps to the mids and highs. The second battery completely stopped my headlights from dimming and holds 14.1 volts, even at full tilt for long periods. If you are going to buy namebrand battery I would do the XS Power. Definitely DO NOT buy an Optima. Otherwise I promise the parts store brand will work just fine. Here's pics of my last two biulds for ideas!
February 11, 20187 yr Author On 2/10/2018 at 10:14 AM, j-roadtatts said: The battery MUST be a sealed type like an AGM. Otherwise will gas into the car. I did the same thing because I couldn't reach the alternator. I bought the biggest battery they had at the parts store and mounted it next to my box. Other route is weld in a battery box next to the spare tire. I am running 2000 Watts to my subs, and two more 600 watt amps to the mids and highs. The second battery completely stopped my headlights from dimming and holds 14.1 volts, even at full tilt for long periods. If you are going to buy namebrand battery I would do the XS Power. Definitely DO NOT buy an Optima. Otherwise I promise the parts store brand will work just fine. Here's pics of my last two biulds for ideas! Thank you sir answer my questions.. I like your idea location battery beside spear tire.. I'm thinking get agm battery from part store for my budget.. In near future will definitely get xp power agm battery.. Thanks in ton.
March 23, 20187 yr Author I try to load up pics my set up bass system.. Did they changed settings? I did load up pics before.. Why?
March 23, 20187 yr Author 7 hours ago, ManzKea said: ?? Sorry... My space is full.. I'm try to free up space to load up pics.. I just couldn't figure it out..
March 23, 20187 yr I haven't uploaded pics directly to SSA in a while, so can't comment on that. But the other option I see guys do, is setup a photobucket account and upload from there.
March 24, 20187 yr On 3/23/2018 at 10:49 AM, j-roadtatts said: I haven't uploaded pics directly to SSA in a while, so can't comment on that. But the other option I see guys do, is setup a photobucket account and upload from there. IMGUR.com is the website to use for now. Photobucket has made the ability to directly link images to a forum post or website a paid feature. Without subscribing to their website with a package that includes that service it doesn’t do any good. I also haven’t found a replacement that’s as easy or easier to use than photobucket was. Imgur works but is much more difficult (at least from my phone) than photobucket ever was.
April 10, 20187 yr Author Thx guys for try help..lol.. Anyways.. I'm happy with my two soundqubed 10s and second battery in back( shrinken) that stops from dimming.. Now i can play bass for one hour straight.. No problem.. But my power acoustik 3000 gets little hot. I'm try to shop around the cooling fan to cool down my amp.. I see some others have like tube fan? Where can i get that? Do i have to make one from pvc cut into two pieces attached fan? Keep bass on!
April 10, 20187 yr On 3/25/2018 at 7:47 PM, jcarter1885 said: I just upload my pictures directly from my phone. I have no idea on how to do this.
April 11, 20187 yr Click on the "Click to chose files" link on the bottom part of this reply box, it will prompt you with options to chose files from your phone's gallery. The only downside is the picture must be smaller than 5mb, so you may have to change your phone settings to allow for a smaller sized picture when using your camera.
August 5, 20187 yr Author Hello all basshead! Lol.. I decided to change system..i wanna go more louder.. So no more soundqubed HDS3.. Hello to new wolframaudio..i order AU- spl single 12.. It should be released middle of September.. The box that I'm going to build is 2.8 cube feet and tune to 33.5 hz.. Along with bigass-port is 6' and 22' long... Anyways can't wait to build.. What do you recommend paint brand to cherry red on port?
November 6, 20186 yr On 1/26/2018 at 7:54 AM, Boom sonic said: I like clean look connection to amp input.. I'm there on that clean look too, but sometimes it's just so much easier to stuff an oversized bundle of wire into a reducer at chest level and then stick reducer into amp all bent over and crouched down.. I've got a few 1/0 to 1/0 reducers that make that stuff so much less frustrating! I think after I got them and realized that it was easier the while clean look thing was out the window. Now the clean look is just a bonus! Edited November 6, 20186 yr by ATX.WeenR
