  • Popular Post
Well,
The Fi came in, so it's time to start a build log. Will continue with pictures of the enclosure as it progresses (might not be for another week or two with Christmas parties and stuff coming up). Rundown of what the system will consist of:
Fi Alpha V2 15 D4, BP plug, Carbon dust cap
Alpine MRX-M100 running at 2 ohms
Factory radio with a Scosche LOC
Ported box with viewing window, SPL dust, and custom fabrication like you've never seen.
  • Replies 60
  • Views 11.9k
  • Here's the current setup (NVX VCW 12) with the amp I'll be recycling for the new sub/box. Also did a quick connection so when we need more space I can remove the entire setup in about 3 seconds.
  • I think wood dye is my new favorite thing to play with. I LOVE this color! And it'll be shining bright with 3 coats of poly on it!
  • 50 cuts later aaaaaaaaand, we've got a port.
Tuned in man :dance:
  • Popular Post
First time I’ve seen that quick connect! Real slick
Like i may have to ask the OP where you snagged that at?
  • Popular Post
Grainger. Product# 3BY23. We used these on big electric forklifts for charging. Thought it'd be a good idea for quick (and safe) removal when needing more space in the Jeep. No need to wrap wires or remove fuses.
  • Popular Post
It's been a few years since I've done this. Just making sure I get my spacing right to have a 180° kerf (90° is for amateurs). Will have to spray the back with water to make it more pliable and less prone to breakage, but my radius should be good with 1/4" cuts.
I knew the connects just couldnt remember from where since I been using a gas forklift lately. Very cool and creative idea man.
I guess I’m an ameteur! Lol. So what’s the measurements??
  • Popular Post
That looks awesome
46 minutes ago, ManzKea said:
That looks awesome
Ive only seen this once before, and it was in a firebird with 4 12's under the window. Subs forward port back. Fella that went by the name AQFirebird. Competed in MWSPL years ago.
So you’re using that as the port itself ?
Really like that port. Can't wait to see the rest. Keep it up.
Correct. That is just the port. 2.5" tall, 21" wide, and 13" long.
How high are you tuning
40hz
  • Admin
Great work.
1 hour ago, Aaron Clinton said:
Great work.
Thank you! I should be finishing the construction after work today, and start testing wood dye's.
  • Popular Post
Well, final construction is done. Just going to let the glue cure overnight before I flush trim the back side, but then she'll be ready for some orange dye and polyurethane! I'm extremely happy with how the box has turned out (especially the port). Oh, and the 9" hole in the front is the viewing window. Everyone does square/rectangular windows, so I wanted to do something different. Also need to buy some LED's to put inside the box. I can't decide whether I want to paint the inside white, or just poly it and leave it a natural finish. Suggestions?
:droolcup: so jealous of your craftsmanship, dope ass enclosure
Thanks! I've been doing this for a few years. My real passion is furniture building. But, all the same principles apply to box building.
