All Activity
This stream auto-updates
  1. Today
  2. jcarter1885
    2015 Hyundai Sonata Sport/Limited
  3. jcarter1885
    Big 2 done so far: Battery Negative to Frame/Chassis Engine Block to Frame/Chassis I covered all unpainted areas with Plasti-Dip to keep from rusting. If I should use something else then let me know, since Plasti-Dip can be removed. I will wait to do the Power and Negative run to Alternator from battery once I upgrade alternators.
  4. jcarter1885
    Couldnt get pictures to upload from my phone for a while but they seem to be working now. Installed my speaker rings back when I got them, love the simplicity of them. I also installed my Speaker Tweakers I won a few years ago from Second Skin in a raffle. To apply them I had to cut in half due to the bar on my inner door skin, super glue worked great as advised from Second Skin. Doors themselves need to be treated one day but for now they got a little love to help improve the sound.
  5. jcarter1885
    Bored at work so I decided to install my Fast Rings around my SSA Evil 6.5" mids. The amount of midbass these speakers put out in an untreated door is unreal, I had too much panel vibration going in. These rings definitely helped.
  6. nigel
    Welcome to the IHoP v.2
    Shot a 144/150 (96%) on my requalification today on our c8 carbine (colt canada canadian version of the us m4/ar15 style platform) Have done better in the past, but overall, satisfied with the score. Still maintained my marksman ranking within the service.
  7. nigel
    Takes time to heal. Emotional damage takes it's toll. Keep working through it and the diet/excercise will come back in due time. Right now focus on the healing, then build back the strength. You'll get there.
  8. Randal Johnson
    Looking for new front stage drivers.
    Relocate the tweeters to the A-Pilars and call it a day bro.
  9. jcarter1885
    Dayton DSP-408, DD Audio DSI-2 or Mini-DSP. Just a few of the cheaper options of DSP's vs the Helix, JL, Hertz etc.
  10. Godsmack
    Keep in mind stress (like this) also does increase water retention and contracts the muscles some. When you've found your way through the feelings you will bounce back. J
  11. Good to know. What would be a good affordable dsp? I already have a Bitone but aint gonna use it too many issues with it and dont wanna spend that money anymore.
  12. nem
    Sorry to hear about Jack,
  13. ///M5
    Sorry Matt. No fun to lose a best friend
  14. ///M5
    You are faster than me! No hurry, do it when it works for you. I REALLY appreciate it.
  15. Yesterday
  16. Tirefryr
    Dude, I'm sorry! Don't know how I missed his passing. RIP Big guy!
  17. dem beats
    Not extraordinarily. I'm sure I've been eating my feelings but nothing sensational. I noticed that I went from thinking I needed to punch a new hole in my belt to backing off from the last existing hole, and my arms/legs look large and less defined than they have been. When I was getting my walks in and squatting every day i started to notice upper thigh vascularity that I've never seen before so it's been a pretty fast weight gain. Probably started before he passed, but now that I stopped working out it's just that much worse.
  18. mikel7829
    Sean I was not at the shop today,I will hopefully be able to have that fabbed up for you by this weekend.
  19. Godsmack
    Diet and alcohol use change with his passing as well? J
  20. Godsmack
    Yikes. That's a big change. That being said, it might bring a lot of new opportunities. Are you able to telecommute or move your position? J
  21. dem beats
    Since Jack passed away I haven't worked out. I'm suuuuuuuper soft and floppy in such a short time. Yikes.
  22. Aaron Clinton
    Possibly a tiny bit of work from home, but her POV has changed to possibly moving all of us up to Cambridge.... edit the rest not for the iHop.
  23. 2 channel i may beable to use. Time will tell
  24. How are you verifying the crossover points? Be careful, easy to melt your stuff. Running active with dials and dip switches on amplifiers IMO shouldn't ever be done.
  25. I thought itll be fine as long it has the 10x switch?
  1. Load more activity
