perfektj
2 FI Q 12's or one 15
Right now I have four JL Audio 10w3v2s in a 2.5 cf enclosure in my Suburban and I am looking to upgrade. My goal is good overall sound quality in my daily driver. Would you recommend 2 FI Q 12's or a single 15? I will be using one or two of my Tru Tech amps depending on which setup I go with. I am using Hybrid gear up front and would like to provide a good match.
Thank you in advance for your time and help,
John
I would choose two 12s.
i would go with two 12's. i have 2 fi q's and they sound amazing as well as loud.
owenmakenna ,
I assume you have two 12's? Also are your subs sealed or ported? What size box? If I go with two 12's I will use two Tru Tech S500s rated at 500 rms but speck out over 700 rms. Is that enough for these subs. I am not looking to break the windows, but if I compete in an SQ class I believe I need to hit 135 db.
Thanks for your help,
John
