raseru
Best Subs For My Goal?!
Alright guys im wanting to change up a little bit here currently im running 1 18" in a 5^3 box(after displacement) on 3K. sounds great if i wanted to put up numbers, but lows arent where i want them and tuning lower wont be the best option because i really cant use this setup in my car anyway, do to weight of extra batts and sub its self, vehicle is lowered and going on 20s. So what i want to know is which would do better in 3.5 to 5.0 cubes tuned to around 25-28hz. (3) SSA Dcons 10"s or (3) IA 187s 10"s ? I like both due to the cost, also i chose 10s so i can seal them foward. They will be ran on a SAZ-1000D and goal is brutal lows (i listen to mainly C&S).
Thanks in advance.
what 18 and what are you tuned to?
I have a tc9/Pierce Audio hybrid now and now im tuned to 34hz. I would tune lower but the weight will make the back rub and im not into walls in Sedans
