Bob345
18" subaru outback build
I just noticed I forgot to post up pics of my amp!! well here you guys go!
and here are some gut pics
and I just got this new head unit
Sorry I was a liittle slow on checkin out the vids. Guess it's movin' some air when you can't hang onto paper blowing out the window! :lol2:
Well it's aBout time I updated this. I just finished wraping the box. Uploading pics now
Edited by Bobobass
sorry for the low quality pics, il get some better ones tomorrow
:drink40:
looking good bo!!!
going to be starting a new box. time to see just how loud a q can get :morepower1:
Edited by Bobobass
what program is that?
the 3d software is solid works and the box calc is tores box calculator Edited by Bobobass
Somethings not right about your dimensions. The calculator is off a bit and your drawing looks like the port is longer then what the calculator says.
[/quote/]
where is the calculator off? and the port is 24". the drawing is exactly what is in the calc. id just like to know what you see wrong before i start building
You should have 3 in the # of common port walls box and in your model it looks as if the wall after the bend is longer then the 2 inches its supposed to be.
thanks for the help. not the worlds best at designing boxes but im learning. heres the changes i made
Now you changed the length in the calculator but left it 24" in the model. And by the way, the 20" port would end in the corner causing incorrect tuning.
its not 24" in the model
OK so the ports 25.25" long, still doesn't explain why you put 20" in the calculator. That enclosure would be 6.58ft^3 @ 33.7hz using your displacements.
:facepalm: stupid mistake. Now I know what I did wrong
now i got the dimensions right. For all you reading this, make sure you mesure port lenght from the center of the port, not the inner port wall like i did. :suicide-santa:
Edited by Bobobass
Bring on the box build pics!!
Going to buy the wood today
finally got to start building the new box. here are some pics of the pieces fitted together
:fing34: Keep us updated!!
