Nice looking alts. Hell I cant even get Nate from Exessive Amperage to email me back let alone make prototypes :=
  • Replies 2.5k
  • Views 235k
  • stevemead08
    stevemead08
    and of course Mr.
  • Mark LaFountain
    Mark LaFountain
    From what I heard, he was far ahead of his competition and could have easily won his class, but the recones failed him and he took 2nd and 3rd for the two classes he was in. We feel very horrible that
  • stevemead08
    stevemead08
It's as wide as possible now all the way down.once I install the port and subs there will no space between them.
only the black one is mine. I can't order my 2nd singer for a few weeks
should get the subs in. port assembled, painted and installed. braces finished tomorrow.
still need to re assemble battery bank. and re install amps maybe wednesday.
wall looks good :)
Pretty.
thanks. Will be prettier when i cant see straight.
Pretty.
que?
Around 38
Damn this is one of the best build logs to follow! :fing34:
Around 38
Thanks, and it still got loud at 30-35hz? How did the subs handle that? My Fi Q 15 subs move very little on their 33hz tuning but If I play then at 30hz they reach their xmax at half volume, I cant play below tuning without the subs going crazy. How do the Zcons act?
Around 38
I'm going to guess that the zcons have stiffer suspension then the Q, so they may take a bit more abuse below tuning.
My zcon drops down to 25hz no problem... but you may end up with torn spiders/etc very easily.
oxymoron?
oxymoron?
Pretty much.
well that's hardly without a problem.
As with any driver it all depends what's controlling it.
I've had zero issues so far. *crosses my fingers*
As promised. subs and port installed
  • Popular Post
That looks sick. If everything goes to plan, blowing out the windshield on wed night or thursday?
ordered my 6 runs of 2/0 welding cable today.
Mike singer still has my alternator.
working on a 20 hole distribution block to manage all my power wires. yes 20. 12 inputs and 8 outputs.
no bumpin just yet. but now that this piece is done i can re-install the batteries and amp
Damn 23,400 views. not bad for a little camaro build.
