Posted October 30, 20178 yr Admin Popular Post Going to start this build log here, going in this truck is a heap of great SSA gear, basically going to showcase a lot of our products. F8L 8"s, IC Amps, Evil Mids & Tweets & Much More! Stay tuned...
October 31, 20178 yr Whats the subwoofer enclosure layout going to be? How many F8L's? Love the interior color of the truck, refreshing to see one that isn't just all black with aluminum trim.
October 31, 20178 yr Author Admin 1 hour ago, S.DeYoung said: Whats the subwoofer enclosure layout going to be? How many F8L's? Love the interior color of the truck, refreshing to see one that isn't just all black with aluminum trim. I am still unsure. Going to wait till it's all worked, shim kit installed, then take measurements and see what we are working with.
November 3, 20178 yr Author Admin Amp rack is going in to house the SSA goodness. Oh yah, and a Flowmaster cat back left Amp had to be mounted higher as there is a seat bracket right there. It's very tight back there. We used the factory Amp bracket to mount to.
November 3, 20178 yr Looks absolutely awesome!! Are you going to use the amp’s built in crossovers, the HU, or another piece of equipment like a DSP for signal processing??
November 3, 20178 yr Author Admin 18 minutes ago, altoncustomtech said: Looks absolutely awesome!! Are you going to use the amp’s built in crossovers, the HU, or another piece of equipment like a DSP for signal processing?? Going to use the amps crossovers, and see how that sounds, add a processor if needed later down the road.
