clemsonhacker
amp question for an FI Q 12
ok here is my question can i run 2 amps (mtx tc4001) on a Fi q 12? the amps are rms 600x1 at 2 ohms. i know that the FI's are dual 2 ohm. right now i dont have the cash to buy the amp i want(sundown). the other mtx amp should be here soon but until then can i only run one VC? is that safe? any answers would be nice? my friend has one of the FI Q 12 in his 06 Z71 and man it sounds great... i want that sound
that amp does not seem to be strapable.
so no....
well.. you could get a O scope and try to match power but that would be silly.
also i that amp is a mono block, and 400X1@2 ohms @ 14.3
do you already own these amps?
does it come with a year warrenty like the one for 250?
good point...lol ... but its a reman
by reman you mean good as new right :neil:
your right...i might just use the mtx in my wifes honda pilot.... unless you can suggest a nice 2ohm svc or a 4ohm dvc to use...
the Q is a nice sub.... you dont need 1000 watts....
is this going in a truck like your friends?
Wire the cols in series and run the sub on one amp at 4 ohms. When the second amp arrives, wire one amp to each coil of the sub. . .they do not have to be strappable to run two of them on a DVC sub. . .
Brian
then how should he match power to ensure that one voice coil is not seeing more power then then other
yes same truck
