holley2346
BTL 18 Box Design?
Was wondering if anyone on here could offer me a reaonable design for a btl 18 for free. I have a guy at the car audio forums that has always done mine for a small fee (they are reasonable).
BTL 18
Tuned to ~30 hz.
~ 5-6 feet ^3
48 inches wide... and max of 24 inches high.
My design is about what your looking for , I am also going to be running a 18" BTL .
My goal was 6ft^3 with all displacement's tuned at 30Hz , slot port . Sub up on top and port back .
Box is designed to fit in my hatchback car so if the dimension's don't work with your space then it can be modified .
Outside dimension's 17" H x 29" W x 34" D . Using .75" MDF I get an internal volume of 8.02ft^3 .
Slot port of 5.5" W x 15.5" H = 85.25sq in port area
Total port length is 32.75" , port board going into the box is 23", plus the .75" MDF face = 23.75" board length .
Without the sub displacement this box is 6.39ft^3 tuned to 29.83Hz .
With the sub the box is 6.13ft^ tuned to 30.47Hz .
The top would be double baffled making the overall outside height 17.75" .
The extra bit of volume provided by the sub cut opening with 2 baffle's of 1.5" H and 16.750" sub cut diameter make's the boxe's final volume ~
6.15ft^3 tuned to 30Hz , 85.25sq in port area (13.87sq in per cuft )
The total port length to slot port internal width ratio is 5.95:1 .
Cut Sheet and assemble in this order ~
Bottom - 29" W x 34" D
Back - 15.5" H x 29" W
Left side - 15.5" H x 33.25" D ( port side )
Right side - 15.5" H x 32.5" D
Front - 15.5" H x 22.75" W
Port - 15.5" H x 23" D
Top - 29" W x 34" D ( need 2 of these with a 16.750" sub cut on both )
I am going to be adding some internal bracing with wooded dowel rods bracing the front to back , side to side , top to bottom , side to the port etc .
Box Width : 48 inches
Box Height : 15 inches
Depth : 20 inches
Wood Thickness is 1/2 inch I believe.... I'm not at the shop
Port Width : 5 inches
Port Length 2 : 6 inches
Will this work with the sub up mounted on the far right of the box?
you definatley need the wood thickness for a BTL to be ateast .75 or even an inhc along with bracing and baffles.
I am fairly sure it is 3/4..... my memory fails me. I have no idea why I would buy 1/2. It would be braced very nicely. :)
Therefore height gets bumped up to 16 inches.
Edited by holley2346
Um, I would go with two layers of the 1/2" if I was you. So one inch total. Might need to reevaluate your plans.
Edit: Nevermind. If its 3/4 with the 16" height should work great. Right at 30Hz. Just under 6ft^3 after displacement. Aint nothin to it but to do it now.
Edited by indytrucks
The wood has already been purchased...... 3/4 inch mdf. Everyone dissed my 5/8 particle board box for 2 18 inch bl's, and after taking it out last week I noticed it had not cracked, come apart, or shown any signs of stress at all! :) At least if it blows apart I can show you an awesome box exploding video. :lol2:
But will that work correctly if I mount the sub up on the fa right of the box?
edit: alright, going to start on it tomorrow afternoon! :) sub comes in tuesday! :):):)
