ANT LAY 4 Posted August 23, 2009 Okay so Fi' s website says 1.75-2.5 Cu ft, but ive heard or read on here that they require a lot of airspace what does need to be at? Looking to order enclosure soon so help would be appreciated! 0 Share this post Link to post Share on other sites
hdrox88 142 Posted August 23, 2009 Sealed or ported. What is your source for the "smaller enclosure?" I would think that Fi is gonna recommend what works for their stuff. 0 Share this post Link to post Share on other sites
ANT LAY 4 Posted August 24, 2009 Sealed or ported. What is your source for the "smaller enclosure?" I would think that Fi is gonna recommend what works for their stuff.Oh, sorry ported (vented) , i got those specs straight from their website but i done a search and found posts saying that they like more space than that 0 Share this post Link to post Share on other sites
jcarter1885 995 Posted August 24, 2009 (edited) Sealed or ported. What is your source for the "smaller enclosure?" I would think that Fi is gonna recommend what works for their stuff.Oh, sorry ported (vented) , i got those specs straight from their website but i done a search and found posts saying that they like more space than thatWhat frequency do you want it ported @, what type of music do you listen to and what amp will be used in this application? Edited August 24, 2009 by jay-cee 0 Share this post Link to post Share on other sites
ANT LAY 4 Posted August 24, 2009 Sealed or ported. What is your source for the "smaller enclosure?" I would think that Fi is gonna recommend what works for their stuff.Oh, sorry ported (vented) , i got those specs straight from their website but i done a search and found posts saying that they like more space than thatWhat do you want it ported to, what type of music do you listen to and what amp will be used in this application?Audioque 2200d, 32hz, and a lil of everything but mostly rap/hip hop 0 Share this post Link to post Share on other sites
jcarter1885 995 Posted August 24, 2009 Sealed or ported. What is your source for the "smaller enclosure?" I would think that Fi is gonna recommend what works for their stuff.Oh, sorry ported (vented) , i got those specs straight from their website but i done a search and found posts saying that they like more space than thatWhat do you want it ported to, what type of music do you listen to and what amp will be used in this application?Audioque 2200d, 32hz, and a lil of everything but mostly rap/hip hopI would make the box 2.5 ft^3 @ 32 Hz and stay within what FI reccommended but Im pretty sure you could go bigger but I wouldnt go to much bigger, what are you trying to build it at? 0 Share this post Link to post Share on other sites
ANT LAY 4 Posted August 24, 2009 Sealed or ported. What is your source for the "smaller enclosure?" I would think that Fi is gonna recommend what works for their stuff.Oh, sorry ported (vented) , i got those specs straight from their website but i done a search and found posts saying that they like more space than thatWhat do you want it ported to, what type of music do you listen to and what amp will be used in this application?Audioque 2200d, 32hz, and a lil of everything but mostly rap/hip hopI would make the box 2.5 ft^3 @ 32 Hz and stay within what FI reccommended but Im pretty sure you could go bigger but I wouldnt go to much bigger, what are you trying to build it at?if you mean what i think, im not going too... unless someone can give a thorough walk through on how to get all the #s, so I AM A probably go with one of our site enclosure builders?! 0 Share this post Link to post Share on other sites
hdrox88 142 Posted August 24, 2009 Let me know your max dimensions and I can design one for ya. I want some more practice in sketchup anyway. If you want to build it yourself that is. 0 Share this post Link to post Share on other sites
Duran 387 Posted August 24, 2009 Sealed or ported. What is your source for the "smaller enclosure?" I would think that Fi is gonna recommend what works for their stuff.You cannot seal a BTL. 0 Share this post Link to post Share on other sites
jcarter1885 995 Posted August 24, 2009 Sealed or ported. What is your source for the "smaller enclosure?" I would think that Fi is gonna recommend what works for their stuff.You cannot port a BTL.You mean you cannot seal a BTL. 1 Share this post Link to post Share on other sites
Duran 387 Posted August 24, 2009 Sealed or ported. What is your source for the "smaller enclosure?" I would think that Fi is gonna recommend what works for their stuff.You cannot port a BTL.You mean you cannot seal a BTL.Thank you very much.Edited. 0 Share this post Link to post Share on other sites
hdrox88 142 Posted August 24, 2009 Sealed or ported. What is your source for the "smaller enclosure?" I would think that Fi is gonna recommend what works for their stuff.You cannot seal a BTL.Sorry for the mix up. I noticed that after I posted that I accidentally put that in there. Figured it didn't make much difference cause if the OP already had seen the specs on the website then it was already known that sealed is not recommended. 0 Share this post Link to post Share on other sites
ANT LAY 4 Posted August 24, 2009 Let me know your max dimensions and I can design one for ya. I want some more practice in sketchup anyway. If you want to build it yourself that is.ok so my width can be no longer than 52in...... my higth and depth both have to be 14"...so itd be ??Wx14Hx14D, and would like it to be 32 hz preferbly straight vented not flared... sorry if i made it hard to follow that but let me know what you come up with and thanks in advance! 0 Share this post Link to post Share on other sites
hdrox88 142 Posted August 24, 2009 (edited) Let me know your max dimensions and I can design one for ya. I want some more practice in sketchup anyway. If you want to build it yourself that is.ok so my width can be no longer than 52in...... my higth and depth both have to be 14"...so itd be ??Wx14Hx14D, and would like it to be 32 hz preferbly straight vented not flared... sorry if i made it hard to follow that but let me know what you come up with and thanks in advance!Ok, Do you want the port and sub firing the same way? Is there anywhere the port or sub cant be due to being blocked by something? Edited August 24, 2009 by hdrox88 0 Share this post Link to post Share on other sites
ANT LAY 4 Posted August 24, 2009 Let me know your max dimensions and I can design one for ya. I want some more practice in sketchup anyway. If you want to build it yourself that is.ok so my width can be no longer than 52in...... my higth and depth both have to be 14"...so itd be ??Wx14Hx14D, and would like it to be 32 hz preferbly straight vented not flared... sorry if i made it hard to follow that but let me know what you come up with and thanks in advance!Ok, Do you want the port and sub firing the same way? Is there anywhere the port or sub cant be due to being blocked by something?oh yea forgot bout that.... yea id like both of them firing same way and speaker tobe centered 0 Share this post Link to post Share on other sites
jcarter1885 995 Posted August 24, 2009 I came up with this design, tell me how it sounds to you:Outside = 14"H x 39"W x 14"DInside = 12.5"H x 37.5"W x 12.5"DPort = 12.5"H x 2.5"W x 22"L (31.25in^2 of Port Area)Port Area Range = 30 - 40in^2Sub Displacement = 0.18ft^3Port Displacement = 0.71ft^32.50ft^3 @ 32.02Hz 0 Share this post Link to post Share on other sites
hdrox88 142 Posted August 24, 2009 Here is what the box will look like. It is very similar to the specs that jay-cee has listed above. I doubt you could hear a difference in the two boxes they are so similar. Let me know if you want the specs and cut sizes of the box I have here. 0 Share this post Link to post Share on other sites
jcarter1885 995 Posted August 24, 2009 Here is what the box will look like. It is very similar to the specs that jay-cee has listed above. I doubt you could hear a difference in the two boxes they are so similar. Let me know if you want the specs and cut sizes of the box I have here.Didnt know you were making a box for him, my fault hdrox88. 0 Share this post Link to post Share on other sites
hdrox88 142 Posted August 24, 2009 Oh, no problem. It's all good. I like to play with this kinda thing anyway. 0 Share this post Link to post Share on other sites
ANT LAY 4 Posted August 24, 2009 Here is what the box will look like. It is very similar to the specs that jay-cee has listed above. I doubt you could hear a difference in the two boxes they are so similar. Let me know if you want the specs and cut sizes of the box I have here.Wow! Great work man and quick work and the specs and cuts would be awesome! 0 Share this post Link to post Share on other sites
ANT LAY 4 Posted August 24, 2009 I came up with this design, tell me how it sounds to you:Outside = 14"H x 39"W x 14"DInside = 12.5"H x 37.5"W x 12.5"DPort = 12.5"H x 2.5"W x 22"L (31.25in^2 of Port Area)Port Area Range = 30 - 40in^2Sub Displacement = 0.18ft^3Port Displacement = 0.71ft^32.50ft^3 @ 32.02HzThanks man both you and hydrox88 rock man! thanks for the help 0 Share this post Link to post Share on other sites
jcarter1885 995 Posted August 24, 2009 Oh, no problem. It's all good. I like to play with this kinda thing anyway.Yeah me too, I have been trying to design the best box for 2-12" in the future. What program did you use, just curious? I use a Box Calculator that I downloaded from a member on this forum, cant remember his name though. 0 Share this post Link to post Share on other sites
hdrox88 142 Posted August 24, 2009 (edited) Oh, no problem. It's all good. I like to play with this kinda thing anyway.Yeah me too, I have been trying to design the best box for 2-12" in the future. What program did you use, just curious? I use a Box Calculator that I downloaded from a member on this forum, cant remember his name though.I did the same thing. From a user...ExpoSport...on ***. Everyone says it is really accurate.Haha. It wont let me mention that forum...thats weird. Something bad must have happened. Edited August 24, 2009 by hdrox88 0 Share this post Link to post Share on other sites
hdrox88 142 Posted August 24, 2009 I came up with this design, tell me how it sounds to you:Outside = 14"H x 39"W x 14"DInside = 12.5"H x 37.5"W x 12.5"DPort = 12.5"H x 2.5"W x 22"L (31.25in^2 of Port Area)Port Area Range = 30 - 40in^2Sub Displacement = 0.18ft^3Port Displacement = 0.71ft^32.50ft^3 @ 32.02HzThanks man both you and hydrox88 rock man! thanks for the helpYou are welcome 0 Share this post Link to post Share on other sites
ANT LAY 4 Posted August 24, 2009 I came up with this design, tell me how it sounds to you:Outside = 14"H x 39"W x 14"DInside = 12.5"H x 37.5"W x 12.5"DPort = 12.5"H x 2.5"W x 22"L (31.25in^2 of Port Area)Port Area Range = 30 - 40in^2Sub Displacement = 0.18ft^3Port Displacement = 0.71ft^32.50ft^3 @ 32.02HzThanks man both you and hydrox88 rock man! thanks for the helpYou are welcomehow do send pm's on here? 0 Share this post Link to post Share on other sites
